Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 59
    Jun 2004
    port st. lucie, fl
    T2x/tillotsen carb rebuild kits
    I know Chrysler/force used tillotsen carbs. Does anyone know an application that I can order carb kits for?
    5 Post(s)
    ...This should be the "repair' kit. Has more pieces to it, than a rebuild kit. Hard to find.
  3. Likes FMP, mrcrsr liked this post
    5 Post(s)
    www.carburetor-parts.com Mike has a number K-5004 "rebuild" kit. Don't know if it will help you or not. What numbers are on your carbs? Parts & pieces(carbs) get changed over time.
    Jul 2005
    Regina SK. Canada
    I think any 120+ hp 4 cly, Chrysler/force will work , If you look through Droll's posts I think he listed specific kits .
  6. Likes mrcrsr liked this post
    Jun 2004
    port st. lucie, fl
    Thanks guys, I'll try and get the carb numbers tonight. It's been a pita trying to get the correct pistons for it. Looks like special order wiseco is going to be the only route.
    Rhode Island
    TSM performance has rebuild parts for Chrysler / force.
    What are you looking for? I use MarineEngine.com and Crowley marine... take the part numbers, and often cross-reference them on Amazon.com. Usually, the websites themselves are cheaper than amazon! Often, individual carb pieces needed are cheaper.
    What's the engine you're working on?
    TC1A or ?
    Jun 2001
    if you contact tillotson they still sell carb kits for the TC carbs.
  11. Likes mrcrsr liked this post
    The later TC as found on F5 etc are a bit different than the earlier ones.
    Jun 2004
    port st. lucie, fl
    Here's what i have tc3 a3Click image for larger version.
  14. #11
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by home made tunnel View Post
    They are off a Mercury t2x
    Jun 2004
    port st. lucie, fl
    Here's another question also, the other engine I have has carbs that are slightly different, the first set from the above number has 2 tubes going up inside the Venturi, the second set off the other engine have 1 tube in the Venturi. Which is a better set to use. A friend said that the carb with the 2 tubes is better. Here is the part number off the other carbs.Click image for larger version.
  16. #13
    The other TC?, Any of the earlier 123456A are virtually the same.
  17. #14
    Jun 2004
    port st. lucie, fl
    I bought 2 powerheads, one was missing crank rods and pistons but is otherwise complete, so I was trying to figure out which set to use for the build. So basically the carbs are the same as far as the carb kits
  18. #15
    I think the earlier TC1A may have had the single pick up tube. I'd have to ask the 135/15O Stacker Bill Edwards to be sure. Maybe they had two version. The TCs I have all two tubes I believe, going to check.
  1. Ebay Rebuild Kits
    By Fisher77 in forum Technical Discussion
    Last Post: 05-10-2016, 07:34 AM
  2. WH-20 carb rebuild kits
    By Derrek Curtis in forum Technical Discussion
    Last Post: 02-02-2007, 09:35 AM
  3. OMC rebuild kits ?
    By Rmart30 in forum Technical Discussion
    Last Post: 01-29-2007, 02:49 PM
