Results 1 to 14 of 14
Thread: Gear set part #
    May 2014
    Livingston, Louisiana
    Gear set part #
    I need the correct part number for the forward/ pinion gear set for a 3.0 L torque master with 1.75/1 ratio. The set I got has a larger bearing on forward gear and a tapered bearing where shaft rides instead of a needle bearing
    May 2014
    In case anyone else ever needs to know. Pinion/ forward gear set part# 43-878087A6 and complete set part #43-828168T3 or 43-859321A3
    Baton Rouge, La
    Asked and answered ! You da man ! Mike
    Cheaters never Win !!!
    May 2014
    Yeah right, if that was the case I wouldn't have ordered the wrong gears in the first place Now I gotta hope they'll take em back since I've had em so long If not I'll have some brand new gears 43-892595A04 for sale on here!
    May 2014
ID:	382706Hats off to Todd D on here for supplying my friend with a nice correct carrrier though!
    Baton Rouge, La
    Sweet ! What gears did you get?
    Might be headed to Belle River Saturday ifn you ain't busy.
    May 2014
    Dang! I'm supposed to going on a guided saltwater fishing trip! I wanna make a Belle River trip!! Y'all wanna bring that 29SRX I got and try it? Those gears and carrier is for my buddies 3.0 liter, he didn't like his coned fishin case we just built so going to the torque master.
    Baton Rouge, La
    I'd go fishing ! Belle River isn't going anywhere. If the weather ever clears up I'll be on a tractor anyways. Hard to make plans this time of year
    May 2001
    great south bay
    Did you happen to sort this out? Did they take the wrong ones back?
    May 2014
    Yes, they swapped em out with no hassle, great folks at pro marine. (My fault in wrong gears, ordered wrong set). The new set worked out fine, the part numbers I posted are the correct ones for the torque master.
  11. Thanks 2.5-21 thanked for this post
  12. #11
    May 2001
    great south bay
    Do you remember what a gear set cost from them? Are they aftermarket gears or OEM?
  13. #12
    May 2014
    They are OEM, don’t remember off hand but definitely more than the 1st wrong ones I got lol. When I get back to the shop I can pull it up.
    On doing your gear swap, you can get just the pinion and forward gear set and reuse your reverse. I googled the number and looks like that set is coming up for $460
  14. #13
    May 2001
    great south bay
    Need 1.75 so all 3 gears will need to be replaced
  15. #14
    May 2014
    Pretty sure only difference between the two is the pinion. Reverse gears normally the same. To save some dough you can just put in matching forward and pinion set. Need to verify that before spending the money, but normally that’s the case. What I done when went from 1,87 to 2.0-1
  1. Replies: 2
    Last Post: 11-11-2015, 02:45 PM
  2. 1.62 3L Sport master Gear set Part number?
    By Jamescole in forum General Boating Discussion
    Last Post: 06-03-2014, 03:36 PM
  3. OMC Tech: Part number question? Gear case gears
    By bigroundrocks in forum Technical Discussion
    Last Post: 08-21-2012, 10:37 PM
  4. Part number for sporty pinion gear...
    By h2oskiier30 in forum Technical Discussion
    Last Post: 05-18-2011, 09:42 PM
  5. Mercury 200hp Dies in Gear (part 2)
    By jbw1776 in forum Technical Discussion
    Last Post: 09-08-2009, 10:41 PM
