Results 1 to 15 of 15
Thread: Transom inspection
07-20-2017, 06:56 PM #1
Member
- Jul 2017
- Mn
- 41
- 19
- 7
Transom inspection
Ok, what do i need to look at to see if the transom is good on a boat i am looking at. Its an 88 procraft 1950v competitor, and visually looks to be in good shape. Any suggestions to figure out if its sea worthy as is?
07-20-2017, 07:44 PM #2
Trim the motor up and push up and down on the cavitation plate to see if the transom flexes.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
07-20-2017, 07:45 PM #3
Screaming And Flying!
- 15,136
- 416
- 1478
- 6113
- 11808
Put the motor in the running position. stand on the cavitation plate and slightly jump up and down. Not like on a trampoline, just slightly. This should not flex the transom or bow the transom top at all. Or, push in the glass where the bottom bolts go thru. Inspect inside the bilge area for any cracks and see what kind of bracing it has. Does it have any screws going into the trans outside? Transducer mount bracket? Speedo bracket? Remove these screws and see if water comes out and look for dark wood or moisture on them. They should have sealer on them before replaced. And you should see sealer on them when removed. Drain plug is another place to check since it is low. On an 1988 I would expect trouble, but sometimes you get a nice surprise. Good luck with it.
John800 thanked for this post
07-20-2017, 08:40 PM #4
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
A tap with your knuckle on the outside around the clamps and elsewhere for a hollow sound indicating core/wood/transom from hull separation. Doesn't necessarily mean it's soft , it can separate if it was too dry or uneven pressure during a replacement or new.
07-20-2017, 10:44 PM #5
Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere !
BUT somethings never change and some problems never go away and just keep reoccurring !!
so moved into Composite Forensics , Now that something completely new !!
One Oldman liked this post
07-21-2017, 07:48 AM #6
5000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
As 'Tunnels" said, if there is wood there check it and any area that have trapped water. If you find any problems chances are there are problems where you can't see.
07-21-2017, 11:49 AM #7
- 15,136
- 416
- 1478
- 6113
- 11808
Oh, that's what he said..
07-21-2017, 12:31 PM #8
From the inside drill a 1/4" hole near where water intrusion is most likely, collect the shavings and inspect them and in the hole with a flashlight. If all is good fill the hole with epoxy. I've done this with core and transoms.
07-21-2017, 12:55 PM #9
5000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
roadkill636 liked this post
07-21-2017, 02:38 PM #10
Member
- Jul 2017
- Mn
- 41
- 19
- 7
07-21-2017, 02:41 PM #11
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
Formerly good friends....lol
John800 liked this post
07-21-2017, 05:27 PM #12
Member
- Jul 2017
- Mn
- 41
- 19
- 7
07-21-2017, 09:57 PM #13
How good is the friendship ?? ignorance is bliss !!
Id still do a lot of poking and prodding with a sharp screw driver in low down places !! you really need to have access to see as much as possible under the floor .
The transom is A BIG PART but what's under the floor is something else entirely on its own and just as bigger major if stringers even still exist !!Last edited by tunnels; 07-21-2017 at 10:00 PM.
07-21-2017, 10:47 PM #14
Member
- Jul 2017
- Mn
- 41
- 19
- 7
He bought it last spring, i helped him test run it and look it over, the guys had it launched when we got to the lake and had fished that am before we got there, then we drove it around for a bit and he ended up taken ng it home. If my memory servs me correctly some of the stringers were visible through a few of the floor hatches and i was suprised at how solid they were and how the bilge looked bone dry, but i will take a look at it again
07-22-2017, 06:06 AM #15
Inspection New Build
By DEN in forum General Boating DiscussionReplies: 6Last Post: 06-25-2017, 12:31 PM -
Boat inspection
By 71454 in forum General Boating DiscussionReplies: 0Last Post: 06-07-2014, 11:26 AM -
86 GT150 crossflow inspection
By traderbob1955 in forum Technical DiscussionReplies: 13Last Post: 08-01-2010, 07:55 PM -
Rod inspection
By gselite2000 in forum Technical DiscussionReplies: 5Last Post: 03-20-2006, 10:15 PM -
Pre Purchase Inspection .. What To Look For??
By bscotti in forum General Boating DiscussionReplies: 2Last Post: 05-17-2003, 08:28 AM
:d
