Results 16 to 30 of 33
    Jul 2005
    Baton Rouge, LA
    I was looking at your picture and thought that's what you had. I'm still using the factory merc regulator instead of a nicer one like yours.
  2. #17
    Aug 2012
    beaumont, tx
    I'm with ya now....yes that's how mine is done....works for me
  3. #18
    Mar 2010
    houston, tx
    Quote Originally Posted by texasvector View Post
    thats a good looking set-up, where did you find the red tygon hose?
    are you running and aeromotive pump also? I have the same reg but running a Weldon pump
  4. #19
    Aug 2012
    beaumont, tx
    Quote Originally Posted by 90 5.0 View Post
    thanks
    found hose on ebay ....1/8" red fuel line used for RC
    im running bosch 044 pump
  5. Thanks 90 5.0 thanked for this post
  6. #20
    I'm impressed with your plumbing also! BTW texas who makes that blue fuel line and the sweet clamps...... I'm in the process of plumbing my Viper. Thanks Gary
  7. #21
    Aug 2012
    beaumont, tx
    Thanks... not sure on brand name of hose...buddy of mine has shop that uses it....1 peice soft rubber hose with liner ....ethanol safe....have to be careful and not roll liner up pushing it on barb
    Clamps are efi hose clamps from orieleys....on push to lock fittings (used to run push to lock hose till it come apart)
  8. #22
    May 2014
    Livingston, Louisiana
    I use a blue push loc hose from Jegs that looks just like that in my boat and on motor. It has a high pressure rating and resistant to all fuels including ethanol. You can also get it in different colors.
  9. Thanks olboatman thanked for this post
    Likes texasvector liked this post
  10. #23
    Attachment 373636
    fixed it for ya.
  11. #24
    Mar 2010
    houston, tx
    I use the jegs push loc hose also, it's made by Gates
  12. Thanks olboatman thanked for this post
  13. #25
    Mar 2010
    houston, tx
    bumping this because of an issue I ran into if anyone else finds this searching, make sure you buy the fuel resistant blue push loc hose, I got some of the wrong type by accident from jegs and it sent junk all into my carbs from the hose coming apart with fuel!!!!
  14. #26
    May 2014
    That stinks! So you found your problem? Which brand hose was it you used? I used the one made by Russell with no problems yet. It was supposed the be for alcohol so I figured it would be good for any fuel.
  15. #27
    What's the "right" stuff... everything on Jeg's that comes up under "push-loc" says "Not for use on brake, fuel, nitrous or power steering systems."
  16. #28
    May 2014
    https://m.summitracing.com/parts/rus-634150
    This is hose I use only found it at summit, couldn't find it on Jegs for some reason. Hope that ain't a bad sign
  17. Thanks David - WI thanked for this post
  18. #29
    Aug 2012
    beaumont, tx
    Get a hold of "hoser" on here....he sells the correct blue push to lock hose rated for efi and ethanol
    The hose I used is not push to lock.
    I previously used earls push to lock from summit or jegs and it come apart
  19. #30
    Comes up on Jeg's with twist-lok name: http://www.jegs.com/p/Russell/Russel...47170/10002/-1
  1. Replies: 2
    Last Post: 03-17-2016, 06:05 AM
  2. Poppet valve/relief valve issues 1978 2.4l Merc
    By rujr in forum Technical Discussion
    Last Post: 06-24-2013, 08:21 PM
  3. Omc solenoid valve
    By Captain75 in forum Technical Discussion
    Last Post: 05-04-2012, 08:46 PM
  4. popet valve
    By geo in forum Technical Discussion
    Last Post: 05-25-2004, 07:33 AM
