Page 4 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 46 to 60 of 248
  1. #46
    Jan 2010
    Venice, FL
    I'd split a pan for a Klondike bar. Sounds like a great idea. Pics please? ...
  2. #47
    Aug 2009
    mpls,mn
    Maybe put a zipper on my lower unit to swap gears and clutch dog on the beach for a better ratio than all I would need is just one prop ?
  3. #48
    Miami,Fl
    That sure would be nice on my laser in fact someone already cut the transom. Does this mean a bunch of v4 fans
  4. #49
    Quote Originally Posted by racervboat View Post
    WISE A$$!!!! Gary
  5. #50
    Aug 2009
    mpls,mn
    Yeah I guess were v-4 fans [were out there] I can get a v-4 to spank a stock 150-175 merc im a fan BUT im also a fan of v-6 mercs too.
  6. #51
    Aug 2009
    mpls,mn
    forgot to mention the shift shaft hole in the can I made slots so I can tack weld the lower plate mount to the steering arm.
  7. #52
    Aug 2009
    mpls,mn
    sst 120 style trim NO TILT must use 5-6 inch set back jack plate,merc outboard trim ram merc or mercruiser trim pump,boat mount for trim ram has 4 positions equals 4 inches of adjustment.Had to cut off about an inch off trim ram mount cause its off set now fits the stock swivel mount perfect,also had to make a bushing to fit the ram size to the swivel bracket size so there you go make your own GOOD LUCK hahahaha but way doable.
    Attached Thumbnails Attached Thumbnails IMG_1736.jpg   IMG_1737.jpg   IMG_1738.jpg   IMG_1739.jpg   IMG_1740.jpg
  8. #53
    Rhode Island
    That's a lot of work to do in one day !
  9. #54
    Aug 2009
    mpls,mn
    read the whole thread I made it first than posted it,if I could make it in one day I would have 50 for sale.
  10. Likes Forkin' Crazy, 71V153 liked this post
  11. #55
    NE Louisiana
    Looks cool to me!!! What hull? You molding in an epoxy torque tab or what?
  12. #56
    Aug 2009
    mpls,mn
    You talking about the lower unit t-tab its already done had to tell in the pic.
  13. #57
    Ft. Lauderdale, Fl
    that would be cool.Did you ever finish it you say started one a few yrs ago ?
    Never finished it, but all that was left was to clean it up and paint it. Sold the engine before I finished it and it went with the engine. For the life of me, can't find the pictures of it
  14. #58
    Aug 2009
    mpls,mn
    Also note the newer can has no exhaust relief holes.
  15. #59
    Aug 2009
    mpls,mn
    And a home made solid upper mount.
    Attached Thumbnails Attached Thumbnails IMG_1750.jpg   IMG_1751.jpg   IMG_1753.jpg   IMG_1754.jpg
  16. #60
    Aug 2009
    mpls,mn
    Although the mig gets the job done one of these days going to buy a tig welder.
  1. The Rebirth of a 30' Velocity Race Deck
    By NJSBOAT in forum General Boating Discussion
    Last Post: 06-04-2020, 11:56 AM
  2. absolute disaster..pain..rebirth
    By bobbowobbo in forum Fiberglass and Composites Discussion
    Last Post: 07-10-2008, 02:50 PM
  3. omc v-8 rebirth ?
    By CALVINPARKS in forum Technical Discussion
    Last Post: 02-22-2004, 04:46 PM
