Results 1 to 7 of 7
    Apr 2010
    Northern wis.
    260 hp Merc Cooling system
    Has anyone used washers with smaller than 1/8" holes in them to get your water temp up a little for early season running? With stock sized washers can't seem to get above 120 degrees. Any ideas? Thanks Mark
    Moline,Ill
    You don't regulate at the washers, it's the holes in the plate
    is gone
    Jun 2008
    Sardis Lake Oklahoma
    Quote Originally Posted by BUZZIN' DOZEN View Post
    OR, the output hoses! When water can't get out as fast it's contained longer and gets warmer!
    Moline,Ill
    The only reason for the washers is to purge air at the last point where the water is at the top of the motor, if you make the holes bigger your dumping water before it goes down through the head.
    Why do you think Mercury adds water to the bottom 2 cyls. on a drag.
    don't mess with the washers they have nothing to do with temp regulation.
    is gone
  5. Likes WillySteve, specboatops, tux974 liked this post
    Mar 2010
    houston, tx
    if you restrict the washers more or the dump hose itself it will hold water in longer and build more heat it can only dump so much out the plate and bottom discharge. You will have to restrict this hose some too to make it work and watch psi to much restriction won't move enough water at high rpm, pressure will shoot through the roof and enough water isn't moving to cool motor at high rpm
    Moline,Ill
    So mercury got it all wrong?
    is gone
    shreveport,la
    I'd run it at 120 degrees.
    Erik Kiser
  9. Likes tux974, racer liked this post
  1. Flushing cooling system, Merc 2.4
    By rujr in forum Technical Discussion
    Last Post: 07-04-2013, 02:04 PM
  2. HOW TO IMPROVE THE COOLING SYSTEM ON MERC 2.5 ?
    By MrCougar in forum Technical Discussion
    Last Post: 08-14-2012, 09:30 AM
  3. Mercury Tech: merc 260 cooling system questions... help please
    By hst714 in forum Technical Discussion
    Last Post: 07-09-2010, 10:37 PM
  4. Merc. cooling system??
    By Promax1R in forum Technical Discussion
    Last Post: 12-11-2005, 09:09 PM
  5. Merc 150hp - cooling system
    By Mark in forum Technical Discussion
    Last Post: 09-17-2004, 04:17 AM
