Results 1 to 7 of 7
Thread: 260 hp Merc Cooling system
05-08-2017, 03:35 PM #1
5000 RPM
- Apr 2010
- Northern wis.
- 222
- 7
- 9
- 52
Has anyone used washers with smaller than 1/8" holes in them to get your water temp up a little for early season running? With stock sized washers can't seem to get above 120 degrees. Any ideas? Thanks Mark
05-08-2017, 04:19 PM #2
You don't regulate at the washers, it's the holes in the plate
is gone
05-08-2017, 04:52 PM #3
05-08-2017, 05:19 PM #4
The only reason for the washers is to purge air at the last point where the water is at the top of the motor, if you make the holes bigger your dumping water before it goes down through the head.
Why do you think Mercury adds water to the bottom 2 cyls. on a drag.
don't mess with the washers they have nothing to do with temp regulation.
is gone
05-08-2017, 08:28 PM #5
if you restrict the washers more or the dump hose itself it will hold water in longer and build more heat it can only dump so much out the plate and bottom discharge. You will have to restrict this hose some too to make it work and watch psi to much restriction won't move enough water at high rpm, pressure will shoot through the roof and enough water isn't moving to cool motor at high rpm
05-08-2017, 08:32 PM #6
So mercury got it all wrong?
is gone
05-08-2017, 08:38 PM #7
Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
I'd run it at 120 degrees.
Erik Kiser
Flushing cooling system, Merc 2.4
By rujr in forum Technical DiscussionReplies: 23Last Post: 07-04-2013, 02:04 PM -
HOW TO IMPROVE THE COOLING SYSTEM ON MERC 2.5 ?
By MrCougar in forum Technical DiscussionReplies: 7Last Post: 08-14-2012, 09:30 AM -
Mercury Tech: merc 260 cooling system questions... help please
By hst714 in forum Technical DiscussionReplies: 4Last Post: 07-09-2010, 10:37 PM -
Merc. cooling system??
By Promax1R in forum Technical DiscussionReplies: 6Last Post: 12-11-2005, 09:09 PM -
Merc 150hp - cooling system
By Mark in forum Technical DiscussionReplies: 0Last Post: 09-17-2004, 04:17 AM
