Results 1 to 15 of 24
Thread: 300x stroker
    Jan 2003
    Georgetown,SC
    300x stroker
    I`m in the process of getting the parts together to build a 3.2L stroker using a
    300x block and electronics.New Pro marine pistons all .030 and a 3.2 300xs crank.Has anyone on here built similiar engine?I read a couple of old posts,but wondering how you like this setup and any problems you`ve had.
    Jul 2002
    S. Florida
    Contact Eric Simon!!! There is a BET Project stroker down here that has run 118 with a stroker (3.2)motor on it,,,, It is a custome made center console..
    07 STROKER 300X
    Sep 2004
    lenoir city,tn
    the 300X block has to be modified to fit the XS crank.
    Jan 2003
    Georgetown,SC
    Are you sure?I talked with eric simon a couple of months ago and he said the crank will clear using a 300x block,but the 300promax block will need to be modified.Have you actually built one of these?
    Jun 2009
    Mims, FL
    Did you ever build this motor?
    2004 Lightning Powerboats FSTV. 3.0L Mercury
    2004 Lightning Powerboats Action. 2.6L Yamaha (Sold)
    1984 Reaction CC. 3.0L Mercury EFI (Sold)
    1996 Mirage River Racer. 2.5L Mercury (Sold)
    1999 Mirage River Racer. 3.0L PM Mercury (Sold)
    Moderator of the Action Marine Powerboats Facebook page.
    https://www.facebook.com/groups/ActionMarineh
    I have a couple of them. Todd D. and Eric worked together on the curve and I have put a lot of fuel through it at this point with no problems. Todd is in the process of putting another one together for my LCB, he will know the answer to any questions that you have.
    louisiana
    just give me your x block, you gunna destroy it anyway. lol
    #5 will self-destruct after a few hrs. its the port timing that's the problem. its just a touch too high.
    #5 leans out
    the word I have is use a 300xs block assembly and use x stuff on it..electronics ect.
  8. Likes Kcraft liked this post
  9. #8
    Quote Originally Posted by xskeetshooter View Post
    #5 leans out
    I have put 600 gallons of fuel through the one on my STV in last 7 months and its an X block. The box has a custom curve put in it from Eric Simon. I am not sure what Xskeetshooter is talking about. I have another one with the XS block, X internals, and all X electronics that is going together very soon for another boat so I will be able to compare the two of them.
    Jun 2009
    Mims, FL
    How to porting compare on the xs compare to the x? We know the xs crank of far better besides the longer stroke. I would think there's new tech in the new blocks.
  11. #10
    #5 leans out.
    I agree that when #5 or #6 burn up , it looks like they were not fed more than a thimble full of fuel their whole life ... what makes you point to the porting ?
    Do you blame the cold , hot or both sides together ?
    If you were Mercury , What would you do if you increased the stroke but used the same piston and rod assembly from a 3.0L ?
    They took the time to balance it , in what other area's did they improve the crank ?
    There's an oil hole in the sleeve below the ports .
    Bottom 2/3 rds of the ex port has a narrower cross section.
    Brand new part #
  12. Likes Frank Molé liked this post
    Quote Originally Posted by BaxterPointYachtClub View Post
    The X cranks got a real bad rap with all of the 05's that broke up near the top (I have two of the victims personally). The XS is a balanced unit so that along with the fact of a fairly low failure rate makes them better. The rods are still the weak link but there are a couple mad scientist in South Florida working on remedies.
    Jul 2007
    southwest Michigan
    I have three 300x block strokers on the back of my 32 skater I built back in 2011, I used Eric Simons recommendations, he reflashed the ecu's and I did the heads and raised the fuel pressure. I have about 200 hours on each with no failures.
    #5 leans out
  15. Thanks Double Rigged thanked for this post
    Likes Capt.Insane-o liked this post
  16. #13
    Aug 2004
    Charleston, SC
    Quote Originally Posted by JPEROG View Post
    Cunninham Rods already makes a great billet rod....unfortunately they've only sold a total of 14 since about 2008 (when Galen Burden had them design some for my race motor). That's why they're now $500 per rod and that is without silver plating which runs about another $75-100 per rod if you can find someone to do it. If enough people got together to place a decent size order, I'd think they could be had for much less but there is still the silver plate issue to deal with.
    For a race motor they make sense due to the high investment of having a block built and the extreme rpms & compression but imo these rods are overkill for a low rpm / low compression lake motor.
  17. Likes Capt.Insane-o liked this post
  18. #14
    May 2001
    great south bay
    Quote Originally Posted by chardt View Post
    Do you have any comparison results with the strokers vs stock motors?
  19. #15
    Jul 2007
    southwest Michigan
    Quote Originally Posted by 2.5-21 View Post
    I picked up 5 mph, acceleration and load carrying capability. I could probably pick up a few more mph's with some taller props, but mid 120"s is fast enough for me in a 32' boat.
    Here is a video of a short test run https://www.youtube.com/watch?v=ftwuiX086Uk
  20. Likes JPEROG, 2.5-21 liked this post
