Results 1 to 15 of 33
Thread: Hookers 101
03-31-2017, 10:41 AM #1
Hookers 101
Not much on here about boats that hook, even though most of us aren't gonna do a 70mph U-turn around a cone for the heck of it.
I own a Stratos 200 VT Rocket and an STV, here say says these are the two worse boats for hooking. I've never hooked one or came close.
But anyway. What is the main cause for hooking?
My guess it's when your taking a hard left turn and your inside sponse touches the water and the vertical inside edge grabs the water with incredible "traction" and doesn't let go. That's my guess. If this is the case how can you control hooking and how are newer boats designed down there to control hooking.
Can you hookers please elaborate on this.
I also see a thousand one liners and jokes coming.
03-31-2017, 10:54 AM #2
Allison's are nicknamed "hooker boats" , I would say those are the worst.
03-31-2017, 11:00 AM #3
5000 RPM
- Sep 2005
- Shreveport, La.
- 910
- 13
- 72
Krazymaan, your hear say is wrong.
03-31-2017, 11:10 AM #4
WillySteve liked this post
03-31-2017, 11:30 AM #5
Byuboyz had a couple threads about Allisons hooking...I have seen a tunnel boat do a "light" hook but the Allisons are the one I hear the most stories about. I have hooked mine once and had several "saves".
Quartermaster
XB2002 W/S3000
davidmercury liked this post
03-31-2017, 11:32 AM #6
5000 RPM
- Sep 2005
- Shreveport, La.
- 910
- 13
- 72
I can't imagine anyone saying that. I am not familiar with the Stratos, but STV's are fine boats, and not prone to hooking. I am not saying that you can't hook one, but they are definitely not known for that.
I am no expert. This is just my opinion.
03-31-2017, 11:40 AM #7If I don't ask any questions, I'll never learn anything.
03-31-2017, 11:47 AM #8
I actually understand what makes an Allison hook. Both of my boats are tunnel hulls and people say the stratos is notorious for hooking and so are the Older STV's like mine. So id like to know some details.
03-31-2017, 11:53 AM #9
DON'T CHOP THE THROTTLE and you'll be fine! Sometimes they hook if you break a skeg or prop or steering but other than inspecting your equipment regularly there is not much you can do about that. My 200VT tried to hook a couple times but it wasn't that big of deal.....it was my fault for abruptly letting off the throttle. In my Stratos I found that I could get it to straighten back out by getting back on the gas quickly. Allisons are a different animal and can turn for various reasons but I think the main cause for the v-tunnel & stv's is chopping. Tail lifts while the nose drops and snags water. That's all I got for ya.
03-31-2017, 12:06 PM #10
only stv prone to hook is the pro comp with the drag bottom. a buddy of mine had one with a 260. the ecu plug came loose and it shut off and driver got ejected! you just cant chop the throttle on this perticular model. he baught it as a all around lake boat and it was never intended to be one so it didnt end up well. the boat got barrel rolled a year after at low speed and he sold it after that. the wrong guy with the wrong boat doing what the boat dosent want to do..
1998 charger stv. 225 promax. -sold-
1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
03-31-2017, 12:23 PM #11
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 7,018
- 681
- 1101
- 1926
- 7989
- 4 Post(s)
This pretty much sums it up-I have a remote water pick up on my stv and I run the case about an inch higher then most with my 10 inch set back. If I chop the throttle, it turns right. Brent lost power with the mod-vp at 130 a few weeks ago and nothing bad happened "very lucky in my opinion". V-front entry boats that transfer to a running pad are a different story, when they grab water with the front or fall of the pad, it is going to typically march in the direction that the bow is now headed and it will take fast correct steering and power input to correct it.
03-31-2017, 12:44 PM #12
This is good info. Maybe I'm not so Krazy after all.
03-31-2017, 07:22 PM #13
Screaming And Flying!
- 15,132
- 415
- 1478
- 6103
- 11797
Most boats will hook from the lower being too high to keep the ass from passing the front. Front is steering the azz. Instead of the other way around.
03-31-2017, 09:07 PM #14
- Jun 2007
- Singapore/Melbourne/Italy
- 9,387
- 1083
- 422
- 4807
- 2211
- 9 Post(s)
I reckon you can just about make any boat spin out, higher the gearbox the easier it is
03-31-2017, 11:02 PM #15
I lost power at 91mph in the little tunnel with a non-ratcheting gearcase. I think the gearcase actually saved my by acting like an drag chute. The boat basically slid around but stayed relatively straight. Ground wire had come off the ECU.
One of our members here hooked his Checkmate with a GoPro running. You can see him tap the up button, a second later you here the rpm go up and nose drop as the prop blows out. Hooked HARD! Hopefully he will post it.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
Hey Snake where ya going to get your hookers now???
By Hottrucks in forum The Scream And Fly LoungeReplies: 32Last Post: 03-12-2008, 05:48 PM
