Page 1 of 11 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 1 to 15 of 165
    Jul 2011
    Gloucester, VA
    I reckon I did OK. 79 Hydrostream Vulture
    Did a bit of trading with a friend. Traded a 16' Lowe Jon Boat (had $200 invested in it) for a 79 Vulture. The core, floor, and stringers where redone a few years ago with coosa. I got the boat complete with all the rigging minus the engine. Has some damage on the starboard side that need to be fixed then I'll paint it.
    I have a few possible power plants to choose from. Old 2.4 175 (has a bad cylinder), 97 175efi, or a early 2000s CDM 200 2.5 fishing motor. Don't really know which will be the best starting platform. I am Mercury certified tech, but I've never had to play with the performance side of things so I'm a bit lost on which platform to start with so any advice would be great.
    Attached Thumbnails Attached Thumbnails IMG_20170310_173559672_HDR.jpg   IMG_20170310_173607041.jpg   IMG_20170308_182635328.jpg   IMG_20170308_182647735.jpg   IMG_20170310_173539140_HDR.jpg
    IMG_20170310_173516807.jpg   IMG_20170310_173506074_HDR.jpg   IMG_20170310_173506074_HDR.jpg
  2. Likes Scream And Fly, noli liked this post
    She's a beaut Clark!
  4. Likes Dave Strong, LakeFever, Hiroller liked this post
  5. #3
    Jul 2011
    Gloucester, VA
    I hope it will be someday.
  6. Likes Hiroller liked this post
  7. #4
    Jul 2011
    Gloucester, VA
    Any advice on what powerhead to start with? 2.4 175, 1997 175EFI (2.5 liter?) Or a CDM 200?
    I have a good 3.0 225 carb powerhead but it's 25" and don't have a 20" mid or case for it.
    melbourne florida
    yuor lucky...the mid section, smooth offshore can is worth the whole rig...stay with the 2.5 or 2.4 the 3 ltr is too heavy and wont fit the mid...the VULTURE they called the BUS because of the longated cocpit...lots of room good luck with it...
  9. Likes 25two.stroke liked this post
  10. #6
    Jul 2011
    Gloucester, VA
    Didn't get the engine. But I got a complete 200 2.5 with a hole in it. And a 2.4 200 with a burnt piston.
    I like the size. Where I live (eastern VA) its rare to have smooth water. While I know I won't be making full throttle runs in 1' chop at least I can get to a creek or the beach.
    I think for the time I might toss my spare 200 fishing motor on it while building/saving for something a bit better. Hopefully it will get me in the 70s?
    Quote Originally Posted by magnum2.5 View Post
  11. #7
    Jul 2011
    Gloucester, VA
    From reading I've ordered a 10" set back jack plate. Any "guess" on a decent prop for a starting point? I plan on plugging the top few intake holes and going up until pressure starts to drop. No nose cone. Gonna be RPM limited to 5800.
  12. #8
    melbourne florida
    with out a lwp 10" setback isway too much...you need a 4" set back so you can adjust the heigth for a stock case...will get on plane easy with the fishin motor and still reach max rpm5800-6000 and maintain water pressure, and ride good in 1 ft chop..with a 24p prop you should see 60+ mph...have fun with it...
  13. #9
    Jul 2011
    Gloucester, VA
    Ok. Should I look into swapping the IGN from one of the parts motors on to the CDM motor to get rid you for the rev limiter and spin it higher? I am planning on swapping to standard cut heads to gain some low and mid. When will the 2.5 200 hit the "wall" around 6500?
    I'd like to have this boat in the mid 70s.
    10 inch setback will be fine. With a standard ignition the late 200 s will pull to 6500 easy. It would be nice if cdi would make a raised rpm limit controller for those motors.
    Jul 2011
    Gloucester, VA
    From my reading it seems they fall in power pretty quick at 6500 and above. Is that correct?
  16. #12
    CHAIN O LAKES, IL
    yuor lucky...the mid section, smooth offshore can is worth the whole rig...stay with the 2.5 or 2.4 the 3 ltr is too heavy and wont fit the mid...the vulture they called the bus because of the longated cocpit...lots of room good luck with it...
    THE MID IS NOT A SMOOTH OFFSHORE.
    ITS A MOD BASS CAN SOMEONE PUT A MAKESHIFT SNOUT ON IT
    Shreveport, La.
    Never heard of using Coosa instead of Balsa for the core. Great for everything else tho. Great find.
    DB
  18. #14
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Da Bull View Post
    DB
    I don't know, that's how the guy did it. He's a fiberglass guy and is obsessed with the stuff. Hopefully it is OK. The boat ran and handled great after all the work.
  19. #15
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by RIVERRUMMER 70 View Post
    Josh Peterson
  1. 20' Hydrostream Vulture
    By xcheesehd in forum Hulls up to 20'
    Last Post: 09-12-2016, 11:12 PM
  2. hydrostream vulture?
    By 16ft superboat in forum General Boating Discussion
    Last Post: 05-25-2011, 09:03 PM
  3. New toy Hydrostream Vulture
    By bahamatrama in forum General Boating Discussion
    Last Post: 09-05-2010, 07:10 PM
