Page 15 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 211 to 225 of 380
  1. #211
    Sitka, Alaska
    When I rigged my Virage I used some cable bezels and put bellows inside them. I had to hog out the inside of the bezels with my die grinder to get the steering hose ends thru. After they were thru, I cut the bellows in half and slid over the hose ends. (VERY tight but with WD40 and two needle nose pliers I was able to pull over)
    The bellows were from McMaster Carr. You can see them on the tailgate on the left side. (I used the larger ones)
    Here they are test fit. I didn't like the bellows protruding this much so I just slid them in and only left one bellow and the collar exposed.
    Ron Pratt
    '91 Virage "The LAST Virage" 300 ProMax
    1989 Voyager XT 200R
  2. Thanks roadkill636 thanked for this post
    Likes Hippie459MN, Slimm liked this post
  3. #212
    A bit of orange peel but oh well
    Attached Thumbnails Attached Thumbnails 20170309_104934.jpg   20170309_104956.jpg   20170309_105019.jpg   20170309_105123.jpg
  4. Likes Slimm liked this post
  5. #213
    Rhode Island
    Quote Originally Posted by AlaskaStreamin View Post
    thats a beautifully expensive tailgate !!!
  6. Likes roadkill636 liked this post
  7. #214
    Rhode Island
    Orange peel? Naaaah. Looks great!!!
  8. Likes roadkill636 liked this post
  9. #215
    Hookn up a Uflex hydrolic steern system with 1500psi Kevlar hoses tonite
    Attached Thumbnails Attached Thumbnails 20170314_175547.jpg   20170314_175633.jpg
  10. Likes Slimm, W2F a V-King liked this post
  11. #216
    Ordered in some bulk #4 tinned wire and made some costom battery cables along with a mazter disconnect swit h and got the mota wired up.and cranking over.
  12. Likes Slimm, W2F a V-King liked this post
  13. #217
    I got the mota started for the first time yesterday. Several problems tho.
    First with a mechanical fuel pump as i was pumping the primmer bulb gas started squirting out of the front of the carbs at tbe bowl vents? The two small holes on top between the inlets.. . I know i adjusteed the floats 1/16" out of the bowls when i rebuilt em. And brand new needles and seats. And using a portable 6 gallon fuel tank the quick connect on the hose was sucking air at the connector. From bad o ring.
    Took the carb off and adjusted the floats to EVEN with the bowl. And still was pushing past the seat and comming out of the air vent holes..
    Ran the mota for a bit and on #4 carb i can actually see fire inside the crankcase! With the fiber reeds they show fire inside the crankcase... not sure if this is too good at all. Or maybee with the bad oring sucking air could that cause the floats to jump around and overfill? And sucking in that much more fuel cause the crankcase fire?
  14. #218
    Rhode Island
    sometimes a tap with a wrench on the side of the carb helps the needle seat. It's sometimes as simple as that to stop fuel from squirting out the overflow.
    Not sure what to tell you about flames in the case... Could be running lean, causing it to sneeze / backfire.
  15. #219
    Found one of the bleed lines pulled off on that #4. ... fire extinguished..gunna recheck the floats again.
  16. Likes Slimm liked this post
  17. #220
    Floats checked out good. But bottom 2 carbs both had a tiny speck sticking in the seat.... problem solved with new inline fuel filter between the pump and carbs.
  18. Likes Slimm liked this post
  19. #221
    Got a bottle of Argon for my mig welder and a spool of 0.035 aluminum wire and welded on a lwp nosecone and pc11 it last nite. Adding more epoxy tonite
  20. Likes Slimm liked this post
  21. #222
    Jul 2014
    Mississippi
    What size bezels and bellows did you use for your steering hoses?
  22. Likes Slimm liked this post
  23. #223
    Sitka, Alaska
    I used the 3/4" cable bezels. Here is the McMaster Carr page I ordered the bellows from. https://www.mcmaster.com/#protective-bellows/=16y9tjr
    Remember I cut them in half so one bellows will do two bezels. The steering hose ends were 3/4" swivel nuts BUT measuring from nut corner to corner was more like 7/8". The bellow "cuff" WILL stretch over this but it is so tight. I thought it was going to split. The neoprene was paper thin as it was going over the nut. Be sure to really lube it up.
    Hind sight, I should have slid a pipe thread x hose barb in the end of the steering hose to act as a shoe horn to help the transition. I must have spent 15 minutes per hose to get that sucker on.
    The Bellows were:
    5298K78 Flexible Molded Bellows, 5/16" Cuff ID, 1" Flange ID, 2-1/2" Extended LG.
    Ron Pratt
  24. #224
    Jul 2014
    Mississippi
    Thanks
  25. #225
    Lifted the Stream off the trailer to weld on new bunk brackets ans paint.
    Attached Thumbnails Attached Thumbnails 20170328_161430.jpg   20170328_154529.jpg
  26. Likes W2F a V-King liked this post
