Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    Jun 2008
    Sardis Lake Oklahoma
    I've really found no CHEAP place to buy a complete system!
    I bought mine in pieces...ie: Helm, Hoses and Cyl at 3 different places and had about $800 total but Hoses and Helm were from individuals, and the Pro Cyl you'll for sure have to buy new if you go that route. There's just no used ones on the market cuz everyone keeps'em and they've even got higher since I paid 400 for mine!!
  2. #17
    Ft. Lauderdale, Fl
    I have always used copper tubing from the helm to the transom then short hoses from transom to the cylinder. AC tubing is rated at like 3000 PSI and no expansion flex. And a hell of a lot cheaper that 20' of kevlar hose.
  3. Likes FMP, WillySteve, W2F a V-King, powerabout liked this post
  4. #18
    Jun 2008
    Quote Originally Posted by flabum1017 View Post
    Great Idea......just make sure to put at least a 1/2 round circle at the ends of the copper to keep'em from work hardening and cracking at 90mph!!!!
    I learned that lesson about 50 years ago on a '57 Chebby oil pressure line
  5. #19
    Ft. Lauderdale, Fl
    Quote Originally Posted by WillySteve View Post
    Nothing like hot oil pissing all over your windshield.
  6. Likes WillySteve liked this post
  7. #20
    5 Post(s)
    So...is it the consensus here, that there is increased steering torque, with higher installed engines, than with lower? Just curious. (I disagree)
  8. Likes FMP liked this post
  9. #21
    Depends on prop and trim angle
    Imho if the hull suits cable n pulley then thats what i would gave and if you dont like the torque, if any use and electric assist on the shaft.
    A few sst45 guys are going this way.
  10. #22
    Ft. Lauderdale, Fl
    With higher engine, torque fin is out of the water. If no torque tab on skeg, yes more torque on steering on higher mounted engine.
  11. #23
    Aug 2004
    Venice, Florida
    Yes the higher the prop the more torque. My boat had single cable steering when I bought it and going up made it harder and harder to hold the wheel.
    21' Paramount
    Mercury 300 Promax
  12. #24
    Jun 2008
    Just consider that the prop is only 1/2 under water and acting like a 5000rpm paddle wheel constantly slappin'da water to one side!
    The more it's submerged, the more it's being counteracted by the water above centerline!
  13. #25
    sebring fl
    high speed//best steering..
  14. #26
    If your boat wants to go left when operating normally, then you have your skeg mounted torque tab the correct size and shape. When going wot it will steer straight w/o a lot of torque steer. Just the way I set mine up....
    5 Post(s)
    Yup. Higher install, use a torque tab. Higher the install, the larger the skeg needs to be. Ala Speedmaster. Its your only touch with reality. Multi engine install, things are a bit different.
  16. Likes WillySteve liked this post
  17. #28
    Sep 2015
    Twin Cities, Minnesota
    That was a great analogy there. One of my boats feel like your trying to hold a one thousand pound weigh over the side of a tall building while trying to walking forward. Its insane.
  18. #29
    Quote Originally Posted by Krazymaan View Post
    duo props for surfacing is the answer...deuce high anyone?
  1. hydraulic steering with steering wheel located trim buttons
    By homeboy6658703 in forum Electronics, Audio Systems, and Wiring
    Last Post: 06-23-2014, 07:43 PM
  2. Replies: 0
    Last Post: 03-28-2007, 03:59 PM
