Results 1 to 10 of 10
02-22-2017, 08:40 PM #1
5000 RPM
- May 2009
- Myrtle Beach
- 99
Reed cage porting advice please. (pics)
I know I am probably wasting my time or even ruining these cages. I could get a 7 pedal front half but I want to work with what I have if I can. I pretty much centered and traced the CCM reeds and opened the openings trying to match the square reeds versus the factory teardrop shape. I still need to clean them up with a file and lap them but I'm only doing one cage before I seek advice and ruin all six. Motor is a 2.4 200 with 6 steel sleeves. Heads shaved, cut front half, block decked and .030" cut off the top of each piston to match the deck. No exhaust work. Worthwhile to mess with the cages? Thanks, Scott
Keaten liked this post
02-22-2017, 10:36 PM #2
Following... also curious...
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
02-23-2017, 07:00 AM #3
All that stuff will help the midrange so it should pull harder but do little (if anything) for top end.
An engine is basically an air pump, the more you put through it, the more horsepower. The biggest gains are in cylinder/piston porting, then you open up intake and exhaust to match the increased flow capacity. Increasing flow in a single area will only provide modest gains.Living in the Freedom provided by Bud Conner and his fellow warriors.
02-23-2017, 08:22 AM #4
5000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Just wondering, why didn't you go with the square 4 petal?
02-23-2017, 08:24 AM #5
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,351
- 259
- 30
- 715
Looks like you're off to a good start,it will help.If you have a Harbor Freight store nearby go get their air file...helps speed things up,Chris
02-23-2017, 08:45 AM #6
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Remember seeing the comparison thread, modified CCM cages and reeds made the most hp anyone have the link?
02-23-2017, 07:05 PM #7
I made a plate to bolt my Erude cages to and put them on a mill and used an 1/8 end mill. Digital readout made them all exactly the same.
stoker2001 liked this post
02-23-2017, 11:18 PM #8
I don't have DRO. I should get it though. would have to go handle revs. 1,2,3,4. 1,2,3. 1,2,3,4. 1,2,3. Not as fun.
02-26-2017, 08:26 AM #9
01-12-2018, 10:15 PM #10
what was the outcome ? did this give good results that were noticeable ?
Mark75H thanked for this post
Who has seen a reed cage like this
By Ripnfool in forum Technical DiscussionReplies: 18Last Post: 09-17-2009, 09:55 AM -
reed cage ?
By 1fastfriend in forum Technical DiscussionReplies: 1Last Post: 03-05-2004, 02:07 PM
