Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
    Sep 2015
    Twin Cities, Minnesota
    What reeds and cages to use for a high performance 2.5
    I have a 7 pedal front half. But what is the best reed cage, reeds and intake to use for a high rpm, heavily ported, high horsepower carburated engine?
    my guess is it would be a 7 pedal with the squarish looking reeds and are all reed cages the same?
    Thanks
    Aug 2011
    ct
    I would say 5 peddle cages out of a newer 280 or some aftermarket billet 4 peddles.
    Jul 2009
    Crawfordville fl
    The high pro cages work as well as any. Mercury pretty had it figured all out.
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
    Sep 2015
    Whats a High Pro cage? Is that one of those large 4 pedals?
    Jul 2009
    Crawfordville fl
    Hi pro cages are what came 260 280 drag
    I like the 280/sport jet blocks.
    Sep 2015
    So what would be one of my best options?
    Jul 2009
    Crawfordville fl
    A set of 5 peddle sport jets or reg hi pro either way same performance. Sport jets are getting hard to find
    Sep 2015
    So are the Hi Pro reeds and cages the large 4 pedal with rubber coated cage?
    If so do you need to change your front half to a 4 pedal front half or does that setup somehow fit into a 7 pedal front half ?
    Nov 2013
    Oak Hill Fl.
ID:	366451Click image for larger version.
ID:	366452The 5 petal rubber coated Sport jet reeds bolt right up to a 7 petal set up.
    http://parts.promarineusa.com/produc...0/1/1/840805T1
    The only hard part about getting them is writing the check.........................
  11. Likes Krazymaan, Slimm liked this post
  12. #11
    Sep 2015
    Quote Originally Posted by dwilfong View Post
    What do you mean? I'd be happy to give you $400 for all six blocks and reeds.
  13. Likes Slimm liked this post
  14. #12
    Nov 2013
    Oak Hill Fl.
    Quote Originally Posted by Krazymaan View Post
    I got lucky and got all 6 for $800 off a guy on Facebook...............
  15. #13
    Sep 2015
    Are the 7 pedal 225 pro max's good reed cages? Do they bolt up to the regular 2.5 front half as long as its a 7 pedal?
  16. #14
    Dec 2011
    Ludington michigan,on the shore
    The seven petal promax are about 95% as good as the sport jets,and cost about 50% less.JMO Iv'e run both and without a clock you won't notice any difference.
  17. #15
    charlotte,nc
    promax part # 840805
    sportjet part # 840425
    The sport jet reeds seem to be a little thinner. I tried some heavier reeds (thanks Chris), but it hurt bottom end response.
    I have been running the SJs for many years without replacing reeds (occasionally turning 9600 rpms with 20P prop)
    The rubber coated cages are quieter, and seal better for great idle.
    I bought mine when they cost about the same as set of replacement reeds.
    death is certain; life is not
  18. Likes Krazymaan liked this post
