Results 1 to 15 of 32
02-03-2017, 09:01 AM #1
What reeds and cages to use for a high performance 2.5
I have a 7 pedal front half. But what is the best reed cage, reeds and intake to use for a high rpm, heavily ported, high horsepower carburated engine?
my guess is it would be a 7 pedal with the squarish looking reeds and are all reed cages the same?
ThanksIf I don't ask any questions, I'll never learn anything.
02-03-2017, 05:58 PM #2
6000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
I would say 5 peddle cages out of a newer 280 or some aftermarket billet 4 peddles.
02-03-2017, 06:37 PM #3
The high pro cages work as well as any. Mercury pretty had it figured all out.
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
02-04-2017, 10:03 AM #4
Whats a High Pro cage? Is that one of those large 4 pedals?
02-04-2017, 10:11 AM #5
Hi pro cages are what came 260 280 drag
02-04-2017, 10:11 AM #6
I like the 280/sport jet blocks.
02-04-2017, 11:01 AM #7
So what would be one of my best options?
02-04-2017, 11:03 AM #8
A set of 5 peddle sport jets or reg hi pro either way same performance. Sport jets are getting hard to find
02-05-2017, 10:10 AM #9
So are the Hi Pro reeds and cages the large 4 pedal with rubber coated cage?
If so do you need to change your front half to a 4 pedal front half or does that setup somehow fit into a 7 pedal front half ?If I don't ask any questions, I'll never learn anything.
02-05-2017, 11:41 AM #10
The 5 petal rubber coated Sport jet reeds bolt right up to a 7 petal set up.
http://parts.promarineusa.com/produc...0/1/1/840805T1
The only hard part about getting them is writing the check.........................
02-07-2017, 09:51 PM #11
Slimm liked this post
02-08-2017, 06:45 AM #12
02-10-2017, 08:47 AM #13
Are the 7 pedal 225 pro max's good reed cages? Do they bolt up to the regular 2.5 front half as long as its a 7 pedal?
02-10-2017, 09:08 AM #14
The seven petal promax are about 95% as good as the sport jets,and cost about 50% less.JMO Iv'e run both and without a clock you won't notice any difference.
02-10-2017, 11:49 AM #15
promax part # 840805
sportjet part # 840425
The sport jet reeds seem to be a little thinner. I tried some heavier reeds (thanks Chris), but it hurt bottom end response.
I have been running the SJs for many years without replacing reeds (occasionally turning 9600 rpms with 20P prop)
The rubber coated cages are quieter, and seal better for great idle.
I bought mine when they cost about the same as set of replacement reeds.death is certain; life is not
Krazymaan liked this post
