Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Jan 2011
    Aston, Pa / Broadkill Beach De
    Rebuilt Powerhead vendors - Opinions?
    Last season my outboard bit the big one.
    Not really sure exactly what happened. It was the first outing of the season and after idling out of the no wake zone, it just bogged down and died after about 30 seconds of 3/4 throttle running. Got it started again, but it was missing bad.
    Its not seized, but had no compression on #6.
    I didn't pull the head, but putting air in the cylinder, I could hear it blowing out the exhaust regardless of the piston position.
    After paying my local shop $150 to tell me what I already knew, I just had it wrapped and winterized because I knew that I would not be able to afford to do anything to salvage the season because my Daughter was getting married in October.
    I've been doing some poking around on the interwebs, and I'm not finding much in the way of used motors in the horsepower I need, 225HP.
    I don't mind a 2 stroke, in fact I'd be more partial to a 2S over a 4S, but I don't want anything older than my current motor, which is a 1996 Mariner 225 Offshore carb motor.
    I'm finding lots of 90-115-150's but not much in the 200-225 range.
    My boat, 26 Leisurecat, came with either a 200 or 225 originally.
    I don't really want to step down to a 200, so 225 is my only option.
    Repowering with new is not an option, the budget won't support that.
    I have found Crowley Marine and Boatpartstore.com having similar prices on reman powerheads, but not much info here on the forums about how good they are.
    I'm leaning towards replacing the powerhead because it's looking less expensive than a used motor with unknown issues or history.
    Opinions or info?
    Thanks.
    I think it would be crazy not to figure out what's wrong with the one you have; and how much it will cost to fix, first.
    It would only take a few minutes to pull the heads off and take some pictures to post here and get a ballpark number for repairs.
    Probably / possibly all the "expensive" parts of your motor are still good.
    Sep 2006
    Key Largo, Fl
    give us a call we can help with your needs.
    chris 305-394-3354
    PARADISE /Naples
    Should be able to find a little guy in your area that has a good reputation, these motors a simple , check around ask others in your area to keep it simple.
    n3up,
    you're not that far from me. I can pickup your powerhead and bring to Fuller's Marine and let them diagnose and fix your motor. when completed, I can bring back to you.
    ==> http://www.screamandfly.com/showthre...ne-Experiences
  6. Thanks vnemous thanked for this post
    Likes olboatman liked this post
    Jan 2011
    I'm planning to dig into it as soon as the weather breaks enough to be able to work outside comfortably.
    Even if I get a reman powerhead, I still will need to pull it first to verify exactly what I have.
    There is no serial number found on it, so I think it's had a powerhead replaced once already.
    I'm pretty sure it's a 96 model year based on other parts on it.
    I think there was a change in driveshaft splines around the 96 MY, so I'll need to verify that.
    Mar 2011
    Rochester,NY
    Noli,that's customer service
    Quote Originally Posted by noli View Post
    n3up,
  9. Likes noli liked this post
    Mar 2005
    Chestertown, NY
    Don't go remanned. I made that mistake a few years back due to lack of time. Debris was left in on the rebuild and marred up the top of one piston and damaged the head. They told me I could send it back and they would assess it. Was quicker to just do it myself. Take up noli on his offer and send it to fullers. Haven't heard a bad thing about those guys.
    1973 Checkmate MX-16 2.0 150 SOLD
    1979 Vector 2.4 200 SOLD
    1988 Vegas XT 225HO D.I.
  11. Thanks vnemous thanked for this post
    Sep 2006
    Key Largo, Fl
    Fullers would be a good choice...
  13. Thanks vnemous thanked for this post
    lindsay on. canada
    do not delay , till spring like every one else . Do it now , spring will be full of get me in the water , new boat and motor rigging and deliveries . Most dealers around here will try to sell you a new motor that time of year ....... They make more $$$$ doing the small fixes and new sales and tell you to come back after the mad rush is over , mid June perhaps ...Just my two cents
    In That You're in Pennsylvanian give Fullers Marine and Machine a call. They are in Bayville New Jersey 732-736-0444. I know George had some Brand new 225 Pro Max bare Blocks. Or I have no doubt he can work something out with you on a rebuild or what ever. Hes also a supporting vendor on here. Great Guy!! Great People all around and Great Friends.
    Quote Originally Posted by n3up View Post
    Opinions or info?
    Thanks.
  16. Thanks vnemous thanked for this post
    Fuller for sure! No disappointment there with those guys!
    IMPO, a 225 Promax/Mariner is a great, strong and reliable motor....
  18. Thanks vnemous thanked for this post
  19. #13
    Oct 2005
    Brick N.J.
    N3up
    Send your motor to Fullers they are very reliable and very honest. You will not be disappointed. They do all the work on my 2.4 Bridgeport
    1985 Team Shadow
    1988 2.4 EFI Bridgeport
  20. Thanks vnemous thanked for this post
  21. #14
    Quote Originally Posted by tux974 View Post
    Isn't his a 3L? Also carb'd are not ProMax anyway, are they?
  22. #15
    Jan 2011
    Yes.
    1996 Mariner 225 Offshore Carb.
    3.0L
  1. rebuilt powerhead
    By team supra in forum Technical Discussion
    Last Post: 08-14-2012, 04:09 PM
  2. Yamaha Tech: rebuilt 250 vmax powerhead won't run.
    By SKIFFY123 in forum Technical Discussion
    Last Post: 03-03-2009, 04:46 PM
  3. Anyone have any opinions on a Berkeley rebuilt pump?
    By waynaferd in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-12-2006, 04:38 PM
