Results 1 to 15 of 25
    Dec 2012
    tn
    Lower unit mis-aligned with mid section 2.5 lt 2000s ??
    Installed a stock lower from a 2.5 lt 150 2002 onto a 2.5 lt 175 2001 stock mid and noticed when assembling the rear end of the lower was off to starboard side maybe 3/32" of an inch- the bolt that goes up under the trim tab confirmed same mis-aligment. It went together easy enough.Overnight I got to thinkin (never good...) and checked the drive shaft this am- it is offset the same amount where it come up thur the mid.Un-acceptable I expect- what would cause this? How do I fix? I have the original 150 mid that matches the lower- it needs TLC and trim put in-
    All the locating pins installed? And clean? Never seen a lower not match up unless there's some damage....
    Dec 2012
    tn
    Locating pins in place-
    There is some history on the mid-section-
    Previous owner hit something hard enough to break the lower mount of the middle/large trim cylinder completely off. Snapped the bottom right off.
    I am running that lower and PH on another mid-section- it was easier to swapped PH and lower since other mid already had a good trim.
    I suppose the mid could be twisted but the other lower is off and running
    Cast alum does not normally bend w/o breaking . But in this case, it may have twisted some from a large impact like you describe.
    Dec 2012
    tn
    That drive shaft mis-align is a NO GO - right? Is there a way to measure drive shaft position - centered in mid?
    I have never had to check it. I really don't know how critical the drive shafts position is. Does not look good though...I would guess that if it is not centered in the adapters hole, it is a deal killer.
    Pekin, IL
    When you set the powerhead it will probably center the driveshaft for you but your lower will still be off and I cannot see that as a good thing. Maybe if you loosen the lower's mounting bolts while the powerhead is in place it will force the lower to where it is supposed to be but then you have no way to verify the lower is in a different place than it is now without removing the powerhead. Good luck.
    Rock
    Team Junk
    Dec 2012
    tn
    Thanks Gents- I had never seen this before - thought maybe someone else had- Probably a good way to ruin a crank and drive shaft- I have other options-
    I will inspect it carefully to see if I can find anything-
    Dec 2011
    Ludington michigan,on the shore
    Pull the lower,take a large file and lightly touch the bottom of the mid.Make sure it is flat and that it is not pulled up slightly around one or more of the mounting holes.Look closely for any cracks.
  10. Likes XstreamVking liked this post
  11. #10
    lindsay on. canada
    pull the drive shaft and check for straight , the mounting surfaces need to be clean and burr free .....
  12. #11
    Dec 2011
    I've seen that type of mis alignment.Its common on mids that have been shortened,and not lined up and squared up.But never a factory one.It would not take much between those pieces to put you off that far at the top.
  13. #12
    Jul 2002
    FT WORTH, TEXAS
    you say mid section can took a hard lick and broke off trim motor bracket it would high unlikly if lower unit is twisted drive shaft bent at a low point in the case is very possible remove it and check it for straight if it not pinion bearing and upper drive shaft bearing wont last long if its forced over to go into crank shaft ,in the 10 years i only rebuilt lower units ive never seen a factory set up be misaligned ive welded countless drive shafts together when you know how they are as strong and straight as none welded
  14. #13
    Jun 2008
    Sardis Lake Oklahoma
    If the D/S was bent it would walk to the other side when turned which I'm sure you've tried. A large flat file should tell you if there's any lumps'r bumps on the mating surfaces.
    Mids are relatively cheap for that engine....I'd use it for a planter for the wife if I couldn't find the problem!
  15. #14
    Have you rotated the driveshaft 180* to see if it favor's the other side ..?
  16. Likes Onetime, NICE PAIR liked this post
  17. #15
    Dec 2012
    tn
    What I noticed was- rear end of the lower was off to starboard side maybe 3/32" of an inch- the bolt that goes up under the trim tab confirmed same mis-aligment
    This lead me to look at drive shaft- which since lower was crooked - drive shaft was offset
    Searching last evening I found front locator pin not centered- you can see with naked eye because it is right in front of the bolt hole(stud back out as they often do).
    Measured and indeed it is 3mm to left of center.
    No damage to pin nor housing- it is simply not centered. I checked 3 more lowers of same vintage to confirm this offset was not intentional.
    This lower was not associated with impact that damaged the trim on the mid. I will dig out the mid this lower came from and check it out of curiosity.
  18. Likes WillySteve liked this post
  1. 175 HP Mercury lower unit and mid section / 125 HP complete
    By CoreyErselius in forum Lower Units
    Last Post: 08-01-2016, 03:47 PM
  2. Lower Unit Mid section mash up Question
    By Krazymaan in forum General Boating Discussion
    Last Post: 07-07-2016, 10:52 PM
  3. need to know lower unit to mid section bolts...
    By Little Jon in forum Technical Discussion
    Last Post: 03-01-2014, 10:59 PM
  4. 300x mid section + lower unit
    By great adventure in forum Technical Discussion
    Last Post: 12-31-2013, 06:50 AM
