Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 100
    GA
    WOW What a classic! It must weigh a ton with all that wood. LOL Great project!
  2. #17
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Quote Originally Posted by One Oldman View Post
    Wood can be much lighter than fiber glass as long you can keep the water out ,so need to make sure its well sealed inside and out !
  3. #18
    Jun 2001
    Boat is suprisingly light. Three guys can pick it up easily. I am guessing maybe 400 lbs?
  4. Thanks One Oldman thanked for this post
  5. #19
    Jul 2007
    light weight glass !! yeah !!
    Quote Originally Posted by Tom Smyth View Post
    In this day and age there is no reason why a composite boat cant be built as light or even lighter than a ply boat using premade glass panels and glassing them together similar to the stitch and tape method ! and a similar framing and stringer system to the wooden boat but all made from composite !!.So if you can build a plywood boat you can build a composite boat the same way ! Just flat panels on a smooth shiny bench almost the exact shape and size and set them up on or inside a set of frames and glass all the joins then fit the framing and tab it in place all same as if you were building using plywood ! Its nothing new !! I have been a part of building a 46 foot tunnel boat and was a breeze !
  6. Thanks Instigator thanked for this post
    Likes NICE PAIR, Instigator liked this post
  7. #20
    Jun 2001
    final fit check on the new stringers and short blocks and transom...
  8. Likes shadowcat, Jimboat, NICE PAIR liked this post
  9. #21
    12 Post(s)
    Quote Originally Posted by tunnels View Post
    I raced kneel down for nine yrs. All 2 cyl classes where weight was king. Several tried glass (80's ERA) and failed.
    All came from a mold.
    I have an old glass patio door I use to lay up flat panels on.
    Your idea would work.
    Sorry for hijack Tom. The boat looks killer!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  10. #22
    Jul 2007
    I fully understand what you are saying !
    Guys built Boats in a mold usually get carried away with a bit extra here and a little more there just for luck ! then before you know it you have a heavy boat .
    Fabrics and the orientation of the glass fibers and understanding what does what and how to get light weight and FLEXIBLITY yet exceedingly strong is something few builders recognize OR UNDERSTAND The old thoughts of it moves it will break is absolute rubbish !! its because it moves it will absorb much more pounding and abuse than if it was stiff !!
    Go sit under a willow tree on a windy day and watch the branches move and twist and never break !
    Materials have changes since the 80s as well and manufactures have not been siting idol picking there noses ,they are continually looking at how to make better fabrics thinner , lighter yet stronger and same concept applies to carbon and Kevlar as well . Making every filament work is the magic key .
    Your idea would work. ah they been doing it for years !!its nothing new !!
  11. #23
    Dec 2006
    Byron Bay, Australia
    You certainly find some very cool stuff Tom!!
  12. #24
    Jun 2001
    pre - drilling the screw holes. Next was mix epoxy glue and screw them in place...
  13. Likes NICE PAIR liked this post
  14. #25
    Jun 2001
    new bottom panel fitted.....
  15. Likes NICE PAIR liked this post
  16. #26
    Jul 2007
    nice job !!
    Have a good and merry xmas
  17. #27
    Jun 2001
    bottom side ready for a few coats of epoxy finally. then time to flip it over and start removing the decks on the top side
    Attached Thumbnails Attached Thumbnails 100_3327[1].jpg   100_3323[1].jpg   100_3325[1].jpg
  18. Likes NICE PAIR liked this post
  19. #28
    Jun 2001
    now we are getting down to some REAL fun........
    Attached Thumbnails Attached Thumbnails 100_3338.jpg   100_3339.jpg   100_3343.jpg
  20. Likes home made tunnel, NICE PAIR liked this post
  21. #29
    Rhode Island
    The more parts that go on, the stiffer the boat becomes - Do you do the wiggle test like I do? ... Grab 1 corner of the boat and lift to see how much it twists? Every new piece put on, the boat twists a little less and less! It's exciting when the deck goes on.
    What will you be doing to the inside of the hull? Just Epoxy coating it? Paint after? Painting the interior White afterwards will show you any potential issues years down the road - Like rot spots will turn brown / etc.
  22. #30
    Jun 2001
    insides will be sanded as access allows and coated with epoxy. I plan to reinforce just about all of the existing repairs. Not worried about adding a few pounds to th eboat, more about longevity. Yes I do the wiggle test and this thing is solid as a rock right now. Decks were only screwed ( stapled) down along the outside perimeter and glued to the longitudinal stringers. I plan to use fasteners at every support structure.
    It is obvious when they built this boat it was not expected to last more than a few years. Now is the chance to make sure this baby lasts for another 40.
    How many other Schulze tunnels still exist in the USA ????
  23. Likes NICE PAIR, home made tunnel liked this post
  1. Trying to identify who owned this Schulze tunnel hull
    By Tom Smyth in forum Outboard and Racing History
    Last Post: 01-12-2018, 03:53 PM
  2. Hot Boat Magazine Classic Boat section
    By Powercat in forum Outboard and Racing History
    Last Post: 10-11-2008, 06:52 PM
  3. Classic Allison Tunnel Hull Photo, 1970
    Last Post: 03-02-2006, 03:12 AM
  4. Schulze Hydro-Cat
    By hydro-cat in forum Outboard and Racing History
    Last Post: 11-05-2003, 08:18 PM
  5. Awesome classic tunnel boat pictures
    By KG4 in forum General Boating Discussion
    Last Post: 11-04-2001, 01:58 PM
