Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 73
    Quote Originally Posted by mjwalters View Post
    I don't understand how a cnc can build a mold? For a plug i get it
    Think of the plug as havimg a surface
    The router knows the surface shape from the instruction set of the CAD
    That same surface is the mold surface, and the router cuts that surface but instead of cutting the foam and leaving behind the plug, it would leave behind the mold
    Also, the mold is done in pieces in foam. One sponson would be done first, then the second, then the tunnel. Then all three parts are put together as creating the female mold in foam. A hardener skin is applied on the foam. And the mold shape is complete
  2. #17
    I wonder if the next biggest version will have Seven Marine outboards?
  3. #18
    chespeake bay md
    Ok. But but the mold will still need to be finished. No?
  4. Likes RobF liked this post
  5. #19
    yes
    painted sanded buffed
  6. #20
    Quote Originally Posted by caldwellrace View Post
    Good looking solid model , can't wait to see the finished boat. This hull may work well with our new fifteen " 3.5/ 4.0 LT CRT motors .
    Will it be ready for the show in february ?
    Probably will not make the show, but Rayzor have said similar ideas about your bigger motor for this cat.
    Will be a great combo
  7. Likes 37coupes liked this post
  8. #21
    Three of Matt's beast would be soooo cool. My guess is that most guys will stay with twin 400s. The cockpit is a lot bigger then the current 32- as is the rest of the boat.
    ...Projected BARE hull & deck weight?
    I was told the turnkey weight with 400Rs is 5200 lbs
  10. #23
    Hull target weight is 27 to 28.
    May 2002
    Ocean Springs, MS
    IM thinking just 2 3.5's turning around 8k should be fun
  12. #25
    No question that would be getting it done. Are the 3.5's going to be splined for 3.0 gear cases?
    May 2002
    Ocean Springs, MS
    yes
  14. #27
    May 2002
    Ocean Springs, MS
    The cases will be custom dry summed and modified for the added tq application .
    I wonder what shaft length Doug plan to settle in on . May check out tomorrow
  15. Likes AZMIDLYF, noli liked this post
  16. #28
    The cases will be custom dry sumped and modified for the added tq application .
    now that sounds fantastic
  17. #29
    Apr 2010
    biloxi,ms
    Wow this is going to be an awesome build. I have been looking and waiting for a boat like this already visited a couple of factory's but this is off the charts. Man this hull with some light weight high horsepower custom outboards would open some eyes. I am definitely going to try to speak with Doug and Matthew on trying to explore this potential. Man I can't wait for this.
  18. #30
    Can handle 15" and 20" mids
  1. All New Designed Doug Wright
    By JPEROG in forum General Boating Discussion
    Last Post: 02-25-2020, 10:38 AM
  2. RGR / Doug Wright 28'
    By Chaz in forum General Boating Discussion
    Last Post: 01-15-2019, 10:25 AM
  3. 32ft Doug Wright
    By Pete B in forum Racer's Hangout
    Last Post: 04-06-2016, 04:25 PM
  4. My doug wright has outgrown her props
    By dan lawrence in forum Propellers
    Last Post: 03-15-2016, 09:38 AM
  5. What's the difference in Doug Wright's and AMT's?
    By bermy100plus in forum General Boating Discussion
    Last Post: 07-13-2011, 04:20 PM
