Results 16 to 30 of 39
11-17-2016, 04:36 PM #16This is the odd ball motor that runs the 2.5 head. I took the chamber down from 42cc to 35cc. Getting a true compression number is hard as there are bleed off ports on these cylindersI would check port height to ensure its a 200 and not a 175....Only the 91 carb 2.5 200 engine had idle relief. The EFI did not
11-17-2016, 04:50 PM #17
That year check bore size.
James Perry
11-18-2016, 01:17 AM #18
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
ive owned two of these motors one i got from james the other james whittled on it so much it much be a 300 drag by now it was as 90 model by stamping but a seven petal with no idel reliefs by still had 2.5 pistons not 2.4 hower some2.4 had sthat looked like 2.5 with pins in them best way to put it all asleep is pull a head measure the hole no more well once upon a time then it is what it is after measureing it
11-19-2016, 05:51 AM #19
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
I pulled the head when I got it because of the confusion. It is a 2.4 bore, idle reliefs are blocked off with factory caps. As stated earlier it took 2.5 heads, efi. When I look up gasket kits, they come up as being only for the 91 175/200 with no head gaskets provided , but cross referencing to other 2.5s of that era and it is the same pn.
11-19-2016, 08:44 AM #20
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
factory cap in idle relief slots is a first for me wonder how that factory notch plug in the sleeve is secured in
im betting its a 175
11-19-2016, 09:19 AM #21James H. W2F a V-King... Want 2 Fly a V-King
11-19-2016, 11:18 AM #22
Must be mistaken what idle reliefs are and something else is capped off? I hope
11-19-2016, 12:47 PM #23James H. W2F a V-King... Want 2 Fly a V-King
11-19-2016, 01:35 PM #24
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
I was wrong. I meant the bleeder ports on the outside of block
11-19-2016, 06:40 PM #25
Happens to all us. I figured you was looking at something else thinking it was the reliefs. While you had head off did you notice if it had the notches above exhaust ports? It would have been great if you would have had something to fill the reliefs though lol! Good luck with your mission. Listen to James Perry, he knows what he is talking about and can steer you in the right direction. And Is a super guy. But remember that each set up, boat/engine combination is different and what works on one doesn't always work on another. This is why there is always diagreement over certain topics. Gather as much information as you can. But when it's all said done it's up to you to experiment and try different things to see what works for your set up. Most of the tricks are not always fully freely given lol.
11-20-2016, 06:09 AM #26
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
I will try to get pictures in the next week.
11-27-2016, 10:50 AM #27
Good News... Its Next Week.
11-28-2016, 05:28 AM #28
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
Power head off, but not on the bench. (Been working everyday). It is the 175 block (884- 9764 under cylinder 5).
11-29-2016, 02:36 PM #29
If it is a fat block 2.4 I would suggest remove the sleeves and number them so they go back in the same holes I then cut the one finger port up to the top of the port from the bottom. I then cut the bottom of the booster to the rod slot. This give a direct flow for the 2 ports and increase fuel transfer as they don't have to fight the moving piston to pass through. This is very similar to a 2.5 which is way better technology. This is similar to when i "TUBE" a engine but there is enough material that it can be done internally. I also include a finial pic of this one as the exhaust chest was also done. This was done before I done them using a CNC program. This engine was a 175 and on a 361 ranger. It picked up nearly 12 MPH on top after the mods and performed from the hole shot to WOT.
James Perry
timmc6 liked this post
11-29-2016, 02:39 PM #30
Mercury Tech: 300X loses power 5500 RPM???
By skate in forum Technical DiscussionReplies: 2Last Post: 08-07-2009, 09:15 AM -
only 7000
By fireedge11 in forum Technical DiscussionReplies: 9Last Post: 01-24-2008, 08:05 AM -
“Big Power Compairo”… How much torque/power difference between a merc 5.0 and 6.0
By blkmtrfan in forum Technical DiscussionReplies: 31Last Post: 04-27-2005, 07:18 AM
). The other 5 are as built by Mercury.
