Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
    Aug 2015
    NE Tennessee
    Agreed, ^^ and even more so if you live in an area where you have hills/mountains.
    James
  2. Likes NICE PAIR, tux974 liked this post
  3. #17
    Aug 2004
    Venice, Florida
    Quote Originally Posted by johnboy 88 vegas View Post
    I come from saltwater where tb's don't last 3 years at best so I despise them on any boat trailer. Tow your boat with a truck that's actually able to stop your rig with no trailer brakes if you have any sense....there is a reason why 3/4 to 1 1/2 ton pickups are made for the average guy.
    You need to switch to Kodiaks.
    21' Paramount
    Mercury 300 Promax
  4. #18
    Ft. Lauderdale, Fl
    Want to add electric and keep the hydraulics? https://www.etrailer.com/Trailer-Bra.../T4822500.html
  5. #19
    Aug 2009
    savannah,ga
    Quote Originally Posted by FrenchPhil View Post
    In Europe, some countries require, by law, the trailer to have brakes if it's rated weight is more than half of the curb weight of towing car/truck. Makes sense to me.
    You would be amazed at how well a F450/550 stops a load compared to a f250/350 truck. You don't even know 10k is back there with the 1 1/4+ ton trucks.
  6. #20
    Central, PA
    Most modern trucks have 4 disc setups capable of stopping some massive loads....now my old 74 ford on the other hand, is not . Your ram pulling and stopping 3000lbs is a piece of cake
  7. Likes XstreamVking, David - WI liked this post
  8. #21
    Many good suggestions but the most important thing I have found is using common sense and good judgement when towing with or without brakes!
    Salt water even with a stainless brake system needs attention at all times if you plan or like having a good operating/working system.
  9. #22
    May 2011
    Japan
    I ran 4 wheel SS discs on my Donzi 22's trailer. Surge system with electric lockout for reverse. They didn't work nearly as well as having brakes on 1 axle (on my heavier Grady 226 trailer). My theory is the pressure to each disc was less when divided over 4 brakes instead of just 2. With SS discs on one axle, I couldn't even backup the trailer unless the electrical reverse lockout was applied (Or override by sticking a screwdriver in the hole to block the surge piston). They worked great. Just hose them off after dunking at the ramp.
    Another safety feature is if the trailer comes off the tow vehicle, the brakes get applied.
  10. Likes NICE PAIR liked this post
  11. #23
    Aug 2004
    Venice, Florida
    You can have all the braking in your truck possible but when your braking hard and the trailer isnt its pushing the back of the truck to one side or the other. If your braking hard your also swerving to some extent. Trailer brakes keep the trailer under control and FOLLOWING the truck not trying to pass or jackknife it. Throw in a wet road and the problem is worse.
    Ive towed heavy trailers with and without brakes and the handling under even moderate braking is very different.
    21' Paramount
    Mercury 300 Promax
  12. Likes Slimm liked this post
  13. #24
    May 2009
    Ormond Beach, Florida
    FYI, Trailer ordered WITH brakes! Thanks.
    Mark
  14. Likes W2F a V-King, NICE PAIR, Slimm liked this post
  15. #25
    Dis assemble and do a preventative grease job on all the bolts and moving parts BEFORE it ever see's salt water.
  16. Likes Slimm liked this post
  17. #26
    Aug 2015
    NE Tennessee
    Yes, just do NOT use never sieze. For salt water.
  18. Likes Slimm liked this post
  19. #27
    May 2001
    Alabaster, AL
    Wet slick road plus panic stop = anti-lock brakes letting you go right through an intersection with a heavy boat or other heavy trailer. That said, I do not have brakes on either my Hydrostream nor my Allison trailers. I would not tow my 24 footer w/o them. I chose Kodiak Dacromet & I wash them after every launch in salt water.
    HydroStream "Spirit of '76" Bicentennial Viper - '96 2.5 200 Pro Max, 15" smooth back mid, SM
    '92 Allison 2003 Grandsport XS - 225 ProMax/20" mid & Sporty, 11" setback
    Newish to me - 2002 StingRay 240LR with a Mercruiser 350 throttle body EFI 260 HP/Bravo 3
    SOLD - 1989 Wellcraft Elite 220XL w/ Mercruiser 350 Magnum
  1. Brakes
    By spbutler in forum Tow Vehicles and Trailers
    Last Post: 08-19-2011, 07:34 PM
  2. !!!!Trailer Brakes!!!!
    By TNT in forum Tow Vehicles and Trailers
    Last Post: 04-10-2011, 04:22 PM
  3. Need help finding some brakes
    By 99f350 in forum General Boating Discussion
    Last Post: 02-01-2009, 10:30 PM
  4. Trailer brakes
    By Scott in MN in forum Tow Vehicles and Trailers
    Last Post: 08-18-2008, 06:03 AM
  5. Which axle should the brakes be on?
    By zgoo in forum Tow Vehicles and Trailers
    Last Post: 07-28-2008, 12:53 PM
