Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 84
  1. #46
    Quote Originally Posted by 16ft superboat View Post
    My buddy Mike ran 107.3 in a side steer viper last weekend. Ran 106 with 3people on board. He will have the baddest and fastest viper around!
    Or he'll kill himself/other people trying. The last days of my boat had 125 pounds of sand in front of my feet and still would run until nothing touched the water but the gearcase, I gave it to a 16 y/o kid and his dad with a 140 inline and feel much better about things.
    Wilber Weeks ran 117 in a Vector in the 70's.
  2. Likes tux974, timw128 liked this post
  3. #47
    Ed, that is insane......
    Tell him to be very careful, it is not worth it. Things happen real quick!!
    IMPO, Not the boat to be running those speeds......
  4. Likes timw128, chopper26 liked this post
  5. #48
    Prince George B.C. Canada
    Quote Originally Posted by timw128 View Post
    I know this is an old thread. I just wanted to comment that Sammie was a friend of mine and he was responsible for popularizing the 'Streams here in Michigan. A friend of mine bought a VKing Comp from him with a special 2.4 6 carb OZ Merc from Oshkosh. I ran Vector Comp's with Baker modded pads and bottoms and Oshkosh 2.4 engines.
    Sammie's mom had a fit over his Viper and the XS, hence the 'Mothers Worry'... here's a photo, although not the best. I have some more, somewhere, taken down at the Detroit River the day it flipped on him.
    Attachment 355646
    Ill bet that SSM hepled with stability over 100 as there would be no need for a larger gearcase for lift on such a small hull with so much power. That looks like an awesome setup!!
  6. Likes Star1, timw128 liked this post
  7. #49
    Nov 2013
    Oak Hill Fl.
ID:	355793Here is a pic of a Cobia bass boat doing 117 back in 1983.
    Tim Thibodaux shard this on Face Book.
    His dad Gene was driving. The boat was own by Bill Holland.
    I thought this was a cool pic as the aero package reminds me of what I have done with my Vector.Click image for larger version.
ID:	355796Click image for larger version.
ID:	355795Click image for larger version.
  8. Likes rjdubiel, timw128, chopper26, NICE PAIR liked this post
  9. #50
    Mar 2004
    Brooklyn Park, MN
    This is the bottom mod to make the boat turn flatter. I want to try it on my Viper. Did you run this on the vector or still in the process?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  10. #51
    Nov 2013
    Oak Hill Fl.
    This is the bottom mod to make the boat turn flatter. I want to try it on my Viper. Did you run this on the vector or still in the process?[/QUOTE]
    Getting close to finishing it up now. Should be ready by the first of next year.
    The mod I did was with aero in mind. I spent some time thinking about it and came up with this air spoiler set up.
    The wedges will only be in the water on take off or slow speed cornering. When up at speed thy will be a aero component to the setup.
  11. Likes timw128, rjdubiel liked this post
  12. #52
    Dec 2011
    Ludington michigan,on the shore
    Tim, you are correct.The 103 was run with a 1to1 speedy 10x17 turning in the 6900 to 7000 range.At the time it was a stock 79 2.4 offshore "vertical reed".After a land and sea drag pack mod,225 front,and OMC big bores,It consistently would turn 74/7500 Never did get a MPH at top rpm.Roger was well into the 90s with a 1500 style sportsman lower,with a L&S plastic cone,and the top two or three water inlets plugged.
  13. Thanks timw128 thanked for this post
    Likes timw128 liked this post
  14. #53
    Oct 2012
    Bay City, MI
    Quote Originally Posted by outasite View Post
    Most excellent, Bob... yes, we used that L&S horizontal front half on a guys 2.4 200 vertical and it made a huge difference with a different tuner. The big gripe about putting a different front half on them back then was that the block and front half were line bored mains at the factory as an assembly. We checked it with a piece of machined round stock during mock up assembly and it was perfect!... seems Merc was just trying to discourage that, or so it seemed.
    I thought Roger had mentioned way back he was getting around 92-93 flat out and around 88 in the 1/4... we built an inline 1500 case using a V6 shaft and 2:1 gears for class racing, too. Bondo'd the side pick up location and contoured some channels from the top of the bullet area directing water to the what would be the lower third of the stock pick up area...if that makes sense. I guess our 2.4's were different...mine came from Oshkosh with horizontal reed layout, fiberglass reeds, lightweight flywheel, etc. We did change mids to quiet it down at low speeds on the lake, but did cut side slots just above cav plate and blocked
    off the thru hub deal. My neighbors hated that boat.
  15. #54
    Oct 2012
    Bay City, MI
    Quote Originally Posted by dwilfong View Post
    The wedges will only be in the water on take off or slow speed cornering. When up at speed thy will be a aero component to the setup.[/QUOTE]
    Hey Dave...you gonna have that deal wet before 2020?... engine was looking good in the last photos I saw. How's the project coming, anyway?
    No, my Vector was set up as a lake and drag racer. Ron Baker did my bottoms while at HS. Filled the concave, moved the wedge transition a bit forward and blueprinted pad and paralleled the area just outboard of the pad, and minor wing tweak. A Vector will not work without some wedge in the pad, and makes for a very dangerous deal. If the Vector running surfaces are done just right, it's an animal out of the hole and will nail a Viking by 3-4 boat lengths in 60'. The extra lift strakes and a bit more dead rise help, too.
  16. #55
    Jun 2004
    Pelican Lake, WI
    I ran 104 and change with mine. Mod 2.5 245 15" 1.87's coned 200 case center steer. The boat was amazingly stable once it got on the pad. I did puff it up once and it was enough for me.
  17. Likes timw128 liked this post
  18. #56
    Nov 2013
    Oak Hill Fl.
    No, my Vector was set up as a lake and drag racer. Ron Baker did my bottoms while at HS. Filled the concave, moved the wedge transition a bit forward and blueprinted pad and paralleled the area just outboard of the pad, and minor wing tweak. A Vector will not work without some wedge in the pad, and makes for a very dangerous deal. If the Vector running surfaces are done just right, it's an animal out of the hole and will nail a Viking by 3-4 boat lengths in 60'. The extra lift strakes and a bit more dead rise help, too.[/QUOTE]
    I got the duel cable steering setup just about done. Doing the last dry fit and check on rigging now.
    Waiting on a set of Geiger Tech heads to show up to finish the eng.
    Should be ready to paint here soon.
    I left the wedge in the secondary pad and put a 3deg V in the main pad tapering to the front. no flat part any where in my pad.
    It should be ready on it's 3 year anniversary of the start of work. River ranch in the spring.
    That's if the $$$ holds out.......LOL
  19. Likes timw128 liked this post
  20. #57
    Oct 2012
    Bay City, MI
    Had a reply all orchestrated and this ****ty site crashed again. When are the SnF IT clowns going to realize they can't jam all of their crap down a small pipe?... too much server load for the cheap ass, flimsy servers. They need to spend some of that ad money on upgrades instead of pouring it into their personal boat programs. Typical performance boaters!
  21. #58
    Aug 2012
    beaumont, tx
    Just wondering so I know what to shoot for with my modified vector.
    Don't think I will have a set big enough to drive it.
    But I bet I can find some one that dose................................
    my modded vector is running 100 mph with a 28 ...still have some setup work to do....and wanna try a factory et 28/30....
    mine runs 98 all day long easy peasy....you gotta take a big swallow ...hold ya breath and bump it again to get the 100 out of it.....
    my goal is a constistant 100 with a 103/104 top number. ive got a coned sporty case hope might get me there
  22. Likes timw128 liked this post
  23. #59
    LOL, it's our internet around here, between 2 and 3 am it crashes or locks up every night.
  24. Likes timw128 liked this post
  25. #60
    Oct 2012
    Bay City, MI
    It's not our internet. Or our gear. It's this SnF site. Period.
