				Results 1 to 6 of 6
		Thread: compression vs octane
	09-03-2016, 07:09 PM #1
Knowing that there is a weight & load consideration but is there a compression to octane requirement. I have 4 200hp heads I will be putting on an 88/92 open deck 225 looper with the stock gaskets. These are the 2.7 heads with the smaller combustion chambers (333108). Not a 100 percent sure of the deck height but I think I'm in the hole. These are stock block configuration. Going to check deck height when I pull the heads. Current heads are the 809 64cc heads 75/80 compression hoping to see 120/130 compression. Motors are on a eliminator 23 Daytona with 28 Mazco's,
Thanks
	09-03-2016, 10:13 PM #2
You won't get that high a change in compression. Or at least I didn't when I did the same head swap. Mine went up to about 105 to 110, but its high enough that you'll need to run 91 octane at least. I got caught out and had to fill up with 87, and fried a piston about 10 minutes later.
				Jim_Pat thanked for this post
	09-04-2016, 10:01 AM #3
						5000 RPM
 - Jan 2004
 - lindsay on. canada
 - 370
 - 14
 - 13
 - 68
 - 34
check the depth of the 2.7 heads ... the clean gasket surface to the closest you can get to the plug hole should be .700 deep . you can run 91/92 . If its less than .700 you need more . Also start richer on the mains ...
	09-04-2016, 11:51 AM #4
	09-04-2016, 12:20 PM #5
	09-04-2016, 03:33 PM #6
						Scream And Fly VIP
 - May 2001
 - Hickory NC
 - 5,624
 - 19
 - 270
 - 215
 - 520
 - 5 Post(s)
Added compression will need 91 octane but they will also need to be jetted correctly and have the timing set at 16 to max of 18 degrees.
Octane vs compression
By David Borg in forum Technical DiscussionReplies: 41Last Post: 09-12-2017, 02:54 PM -
OMC Tech: Necessary Octane - V8 with 145 to 150 compression?
By Li'l Toy in forum Technical DiscussionReplies: 30Last Post: 06-01-2015, 01:37 AM -
safe compression with 93 octane and aces octane boost
By woundedwarrior in forum Technical DiscussionReplies: 7Last Post: 04-25-2013, 06:41 AM -
what octane to what compression
By garhide in forum Technical DiscussionReplies: 5Last Post: 05-22-2010, 10:23 AM -
compression vs. 93 octane
By MIKEF18 in forum Props, Setup, and RiggingReplies: 1Last Post: 04-05-2007, 07:47 AM
