Results 1 to 8 of 8
    englewood florida
    Low water pressure with my 1 piece adapter
    Ever since I put a 1 piece adapter on my 2.5, I've had great water flow but very low pressure. I've had no problem with temperature. Is there something to do to get better pressure?
    18 Action 225 Promax
    Aug 2012
    beaumont, tx
    what plate? 280 style with large dumps out to the can? what u doing with poppet hose?
    Quote Originally Posted by rkmirage View Post
    Ain't broke, don't fix it.
  4. Likes tux974, Dave Strong liked this post
    Aug 2011
    ct
    All my 1 peice plates with the big dumps have low pressure. Just run it
  6. Likes tux974, Dave Strong liked this post
    englewood florida
    Quote Originally Posted by superboattwin250 View Post
    Thanks, just wanted to make sure.
    jonesville, La
    1 piece plate = low water pressure, usually 0 at idle and marble 7-8psi at 7k at best on a 2.5
    Dec 2011
    Ludington michigan,on the shore
    ever since i put a 1 piece adapter on my 2.5, i've had great water flow but very low pressure. I've had no problem with temperature. Is there something to do to get better pressure?
    go faster!
    englewood florida
    Quote Originally Posted by pappa pete View Post
    Exactly where its at.
  1. Mercury Tech: Goin from a 2 piece adapter to a Once piece...Water relief???
    By sicknick12 in forum Technical Discussion
    Last Post: 05-26-2018, 02:24 PM
  2. Fresh water Mint Mercury Bridgeport 1 Piece Adapter
    By scottistang in forum Misc. Parts and Accessories
    Last Post: 05-09-2016, 05:45 PM
  3. 98 ProMax - Water Pressure Adapter fitting
    By stace911 in forum Technical Discussion
    Last Post: 08-11-2014, 07:37 PM
  4. Replies: 0
    Last Post: 09-29-2013, 09:02 AM
  5. Mercury Tech: No water pressure after adapter plate switch?
    By Hull-lifter in forum Technical Discussion
    Last Post: 07-01-2011, 10:52 PM
