Results 16 to 30 of 36
    Just don't push the service as far as have in the past "dropping parts off at midnight" LOL... Charlie is one of the best for sure. When Scott Porta is impressed with someone's welding ability then you can be assured that he is the real deal. He has saved many blocks and cases in his day and the end result is always a TEN.
  2. Likes NICE PAIR liked this post
  3. #17
    minocqua, wis
    work like that is worth the wait!!!
  4. Likes NICE PAIR liked this post
  5. #18
    MIAMI FLORIDA
    I second that, he does some amazing machine work. Dave
  6. Likes tux974, NICE PAIR liked this post
  7. #19
    new york babylon
    Nice work
  8. Likes tux974, NICE PAIR liked this post
  9. #20
    Feb 2005
    seattle
    no matter what, pin the nut with some 10/32 SS bolts
  10. #21
    Quote Originally Posted by hsbob View Post
    No need to pin the nut if you use the wide one. OMC that's another story.
  11. Likes tux974 liked this post
  12. #22
    Quote Originally Posted by Todd D View Post
    Lol. Only if you bring cannolis!!
    Never underestimate the power of a good cannole' ....
  13. Likes vnemous, NICE PAIR liked this post
  14. #23
    lost in Tennessee
    Hey Chaz, can you repair XR6 cases as well?
  15. #24
    Quote Originally Posted by Chummy View Post
    send him a PM. He may not look at this link.
  16. #25
    lost in Tennessee
    ok will do
  17. #26
    Chummy ,
    I just sent you a detailed response to your PM ...
  18. #27
    I found a few pics to go with what I was saying .
    weld the housing bore ...
    bore to size ( or oversize depending on condition )
    More times than not , the case needs to be bored .005 - .015 bigger to get the hole round again .....
    Chase threads ....
    Once the case is complete ....
    Then I weld a small amount of filler around the rear load bearing area and turn it down to the new OD ..
    Recut the keyway slot and it's ready to go ....
    It does marry the carrier and case together as it a unit that wont interchange with other stock parts . But it will put those parts back in service , rather than throwing them in the .44c a pound scrap pile ...
  19. #28
    And the Threads that the other guy did looked like they had been chewed back into the case. I had to clean them up then I coated them with a DFL (Dry Film Lubricant) coating. This not only protected the Nut and case threads from corrosion but made that Nut almost glide itself in.
    Quote Originally Posted by Dave Strong View Post
    The other guy was a one man show and more work than he could handle. I was lucky that Bud got on his case and somehow got him motivated to get mine done. Then it went to Bud for stainless powder coat. If I ever need it done again I will be sending it to Chaz, no problem waiting to get the job done right.
  20. Thanks Dave Strong thanked for this post
    Likes Dave Strong liked this post
  21. #29
    Quote Originally Posted by HStream1 View Post
    And the Threads looked like they had been chewed back into the case. I had to clean them up then I coated them with a DFL (Dry Film Lubricant) coating. This not only protected the Nut and case threads from corrosion but made that Nut almost glide itself in.
    Just to be clear. What Bud posted above was not about Chaz's work but the person who did Dave's case. FYI
  22. #30
    ^^^ Thank you My friend. I did make a correction to better clarify it wasn't our Buddy Charlies work
  23. Thanks vnemous thanked for this post
  1. 3.0 Sportmaster Billet Seal Housing & Shift Shaft Housing
    By alli-runner in forum General Boating Discussion
    Last Post: 12-27-2010, 08:25 PM
  2. sportmaster gear housing repair
    By mrcrsr in forum Technical Discussion
    Last Post: 08-14-2009, 06:29 AM
