Results 1 to 11 of 11
Thread: 11350 a27 box
06-26-2016, 02:20 PM #1
11350 a27 box
these early boxes are analog correct? cannot be remapped? can they be adjusted % wise with screw?
any pros / cons are welcome81' HYDROSTREAM VECTOR / slightly Modified 200
06-26-2016, 02:23 PM #2
Not sure on remapping Cody ,adjustable for sure ,we use to run dials to the cockpit on them.
texasvector thanked for this post
06-26-2016, 02:40 PM #3
hows the a27 map.....ive only used a48 and a6
06-26-2016, 02:44 PM #4
It is a good curve.Rapair use to work them and do a good job,but that was years ago.
06-26-2016, 02:58 PM #5
I'm talking of something I know little about,but I think the analog box would need the old style harness with TPS input,I have a couple early A38s that were converted to A48 I would like to try on a early 260 on the Switzer,that is now using up one of my Brucatos.Im thinking that the BP harness can be made to work about any combo
06-26-2016, 03:08 PM #6
yes ...ive been told they need the tps...friend of mine is interested and has 2.4 horn....i have laser setup
06-26-2016, 04:03 PM #7
5000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Is yours potted? If not Marles has chips.
06-26-2016, 04:09 PM #8
In 95 they made an analog box that didn't use the mechanical tps, right before the digital came out
is gone
WillySteve liked this post
06-26-2016, 04:11 PM #9
06-27-2016, 03:23 PM #10
07-05-2016, 07:26 PM #11Markus' Performance Boating Links:
By silverado5.3 in forum General Boating DiscussionReplies: 1Last Post: 05-09-2016, 05:27 PM -
ECU 11350 A 45 or 46 or 53
By ALLAN DENNIS in forum Technical DiscussionReplies: 0Last Post: 10-29-2003, 11:08 PM
