Page 30 of 42 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 LastLast
Results 436 to 450 of 622
  1. #436
    Western Pennsylvania
    "Timing set to 136* btdc." Is that a typo? Not sure what it should be but most are set in the low 20* area especially with increased compression.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  2. #437
    Sounds Great!!!!! Good luck tomorrow and can't wait for some news after the test run!!!! Gary
  3. #438
    Rhode Island
    Quote Originally Posted by Euroski View Post
    36* btdc. High octane fuel too.
  4. #439
    Oh come on and I thought it sounded so good because you had the stones to timer up!!!! lol Gary
  5. #440
    Rhode Island
    HA ! Ok ok ok - I'll go 136* ! ! ! Zoom Zoom Boom ?! I don't think it would even Idle at that setting haha.
    I did have to yank the flywheel off to get the timing right because I aligned the stator a bolt hole off - I could only get 10* advanced at the farthest setting on the trigger. Yanked the flywheel, clocked the stator another bolt hole, and voila... all better haha.
  6. #441
    Aug 2015
    NE Tennessee
    Did you mark TDC on the flywheel for all 3 cylinders and set timing from the one that read the most advanced?
    James
  7. #442
    Use the NGK . http://www.marineengine.com/newparts...m=MER1395-6207
    If you start wit these you can drill them out. Or try the jets from a 105 Chrysler .086 .084 but that will be too rich. Check the plugs again after a few hrs. Fresh fuel good oil and psi will show .
  8. #443
    With these X flows stock is 30-34. This style with 195+ psi and proper fuel in race tune would be 36+* .
  9. #444
    Quote Originally Posted by home made tunnel View Post
    Got some new plugs to try. They don't stick out too far- the autolite equivalent of ngk with the traditional gap.
    What did you gap them at? NKG BUHW is .050 . BUHW-2 is .072 but that might not work with the ign.
  10. #445
    Rhode Island
    I've decided I am just going to buy some other stock jets and drill them out bigger. It's even hard finding drill bit kits for .078" / 0.080" / 0.082" to try out.
    Hope it runs well this afternoon!
  11. #446
    Need Number drill bits #47, 46, 45. Chart link..
    http://7id.xray.aps.anl.gov/tables/number_drill.html
  12. Likes Slimm liked this post
  13. #447
    Rhode Island
    Ran it today- runs fine on the driveway but like poo in the water at idle. I need to do the idle air jet adjustment all over again.
    So it has Way more power it feels like. I just cruised around a bit and it is no effort at all to hit 5krpm- like wayyyyy easy 1/3 throttle. So I still need a bigger prop and prob better gears.
    Heres the plugs-cyl 1 is lightest. Cyl 3 is darkest. (Also the one that fried before.) I haven't checked each chlinder to see which is most advanced yet.
    Attached Thumbnails Attached Thumbnails image.jpeg   image.jpg   image.jpg   image.jpg
  14. #448
    On the plugs?
    First plug could use bit more gas, as second look pretty normal to me but maybe a tad rich. Last? Thats REALLY needing gas! Need some "chocolate brown" insulator like #1. Just my dumbass opinion...........
  15. Likes Capt.Insane-o liked this post
  16. #449
    Rhode Island
    Just an FYI- that pic with all thre in it that says lean rich and normal, those aren't my plugs. Just for reference lol
  17. #450
    YOU don't want a repeat of #3 so try to check the timing , try a little bigger jet in #3 than the rest . What is could be is the ex port size you now have and the ex mix that is getting into #3 from the stuf before close and the heat from that, but haven't seen it on #4 on the L4.
  1. Never mind Quints
    By Wayne Cammidge in forum General Boating Discussion
    Last Post: 02-19-2015, 05:29 AM
  2. Mind if I vent?
    By QUICKSILVER in forum The Scream And Fly Lounge
    Last Post: 10-21-2003, 10:22 PM
  3. Keep An Open Mind
    By mr.clean in forum The Scream And Fly Lounge
    Last Post: 10-09-2003, 12:23 AM
  4. Tell me if I'm out of my mind!
    By cdaspeed in forum Props, Setup, and Rigging
    Last Post: 08-26-2003, 09:31 AM
