Results 1 to 15 of 17
    Sep 2015
    Atlanta
    Liberator 21, 300XS w/ SM & 1.75--help pls
    Not sure where to start or how to cost effectively try different props. 300XS with sportmaster and 1.75 gears. More interested in hole shots and cruising between 35 and 70mph. 90 top would be ok.
    Where do I start with dia and pitch. Based on reading past posts would a 14.5" or 15" diameter with a 34P be a good start?
    And how do you experiment without going broke on props?
    thanks in advance!!
    Quote Originally Posted by wasvette View Post
    thanks in advance!!
    28 or 30 Drag Four or Merc Pro ET will do what you want. An XS has the torque to spin the bigger dia. and it will also be better for carrying weight. A 30 will be just over 90 and a 28 will be just under but both will pull hard with a 75.
  3. Likes specboatops liked this post
    Sep 2015
    Atlanta
    Quote Originally Posted by JPEROG View Post
    Thanks Joe! You guys are really helping me out (and saving me $'s) as I learn about these boat/motor combos. The extent of my 'go fast' experience is a '78 Hydro Vandal with a Merc 90 when I was a teenager. So, when you say 'larger diameter' are you referring to a 15" ...or larger?
    Thanks again!
    Kevin
    Feb 2010
    wisconsin
    Find some people locally and see what they will let you try if they have any props or Call up BBLADES propellers out of princeton, WI . Both Brett and Brad there will be able to hook you up and they also have a prop testing program you should look into.. Waaaaay cheaper than buying/trading props..
    Thanks again!
    Kevin
    15 or 15.25 will be good. If you need you can always have it cut down.
    Jun 2011
    Norcal
    Call Bret at BBlades. Great demo program and great props.
  8. Likes wicheckmate liked this post
    Sep 2015
    Atlanta
    Thanks guys. I'll call Brett. Sounds like good plan.
    Apr 2015
    Jacksonville, FL
    if you ever come down to Jacksonville, I have a new 30 Bravo XS you can try.
    Sep 2015
    Atlanta
    Quote Originally Posted by SuperPro View Post
    Thanks Superpro - That's very generous!!!
    Starting with a Merc ProMax 14.5"x 28p as an everyday prop for good hole shot and cruising 30-65mph. No idea where I'll end up though RPM-wise. Will experiment with pitch for top speed later.
    Apr 2009
    Rochester, NY
    propeller
    Wasvette I can build you a brand new custom propeller that will perform the way you want?
    Sep 2015
    Atlanta
    Quote Originally Posted by Spinelli Propellers View Post
    Thanks - I'll definitely keep that in mind when we're ready for a prop more optimized for speed. Since I'm new to all this, how would you configure the custom prop without testing a few different set ups on the boat?
  14. #12
    Apr 2009
    Rochester, NY
    Propeller configuration.
    We would go over your current propellers performance and boat attitude/rigging.
    I would then do my calculations and build you a custom prop for your application.
  15. #13
    Sep 2011
    illionios
    I will tell you My boat is almost identical to yours I have a drag 4 that prop that prop is great out of the hole and at 6500 RPM I'm turnabout 94 miles an hour I have a 300 X on mine and my motor as less than 100 hours new not rebuilt I personally don't Know if it would pull a 32 i'm getting ready to try and 29 on mine With a custom DeWalt 28 five blade I pulled 101.4 at 7000 rpm my hull is a little heavier than yours though sounds like you'd be real happy with the 28 drag for See if you can try one
    Adrenaline junkie for life
  16. #14
    Sep 2015
    Atlanta
    Quote Originally Posted by rapidcraft22 View Post
    So to clarify, you have a 28P drag 4 that is getting you to 94mph? Thanks!!
  17. #15
    Sep 2011
    illionios
    Yes The only difference is Iam running a 1.62 gear that prop is great out of the hole
  1. New 25 Liberator cat with twin Merc 300xs
    By WILDMAN in forum Hulls larger than 20'
    Last Post: 08-22-2017, 10:12 PM
  2. New 2016 21 Liberator cat with Mercury 300XS
    Last Post: 01-24-2016, 01:43 PM
  3. Just finished 21 Liberator. 300XS 106.4 mph!
    By WILDMAN in forum General Boating Discussion
    Last Post: 07-17-2007, 03:06 PM
