Results 1 to 6 of 6
    Apr 2016
    Sweetlake, La
    Yamaha 25 3 Cylinder
    Wanted to get opinions on this cowling I set up on my Yamaha. I fiber glassed this scoop in and painted the motor myself. Would forced induction help, or could possibly hurt performance. Foam packed in scoop while towing my boat etc. Also I am inquiring on having this motor ported , 12p turbo, cmc pt130, hydrotec head and tuner, tohatsu M40D carbs, Yamaha 40 reed block, Chris Carson reeds, revlimiter removed, fully loaded running 34mph with dual batteries, two bank minn kota charger under front deck 80lb trolling motor
    Thanks Casey
    Jan 2016
    Naples FL
    How big is your boat? My old 30hp ran 38 mph with a power tech sra3 13p. I used 125 jets because the stock 122's in the 40hp carbs were lean. You can't find them for the tohatsu anymore, but these work great http://www.boats.net/parts/detail/ya...343-63-00.html
    The 2 cylinder yamaha uses the same carbs as the tohatsu 40hp.
  3. Thanks Casey Bridges thanked for this post
    Likes Casey Bridges liked this post
    Apr 2016
    Sweetlake, La
    Tiller guy thanks for the info. Going to have those jets ordered. Boat is a 16x46.
    Quote Originally Posted by Tiller Guy View Post
    Not to step on this thread but maybe Tiller Guy could give me some advice on what I can do to tweek some more out of my 1988 2 cyl 2 carb 25hp Yamaha I use on my 11ft SLT. Larger carbs , different tuner etc. Thanks Gary
    Jan 2016
    Naples FL
    I know someone that's running a modified 2 cylinder yamaha and everything was done by hydro tech. Port work, head, bored carb, reeds and tuner. There's plenty that can be done, but I only have hands on experience with the 3 cylinder.
    Thank you! I will check with Hydro Tech. Gary
  1. 25hp Yamaha 2 cylinder?
    By rustyolranger4x4 in forum Technical Discussion
    Last Post: 01-24-2016, 08:26 AM
  2. WTB - Yamaha V4 6E5 cylinder heads
    By Mr. Demeanor in forum Parts Wanted
    Last Post: 06-11-2014, 11:09 PM
  3. Yamaha cylinder specs. ?
    By CNT in forum Technical Discussion
    Last Post: 07-07-2006, 06:35 PM
