Results 1 to 15 of 26
04-21-2016, 11:58 PM #1
Member
- Oct 2015
- Kennewick Wa
- 62
- 10
- 13
2.5 offshore 260 smoking badly at idle
I have a 2.5 offshore 260, well that's what the mid says on it!, anyway it has all of the sudden started smoking at start up and I don't mean normal smoke I'm talking a lot to the point of embarrassment but as soon as u take off and start going it instantly goes away and runs just fine, it also has not been wanting to idle as well. It did not do this before winter came only now that I have taken it out for the first couple days of season. I know the motor is down on compression but they are all equal and it still hauls ass on the back of my HST. It obviously is loading up while trying to idle and it also does it even if the motor is a normal temp. I run the Mercury premium synthetic oil and I even tried mixing it the second time out at 40:1 but no help. Could this be that it needs new plugs as I have not changed them since I bought it ?? Thank u in advance for any help.
04-22-2016, 06:08 AM #2
year and ecu number would be a good start.... picture of tha power head....
04-22-2016, 06:58 AM #3
could be your air temp sensor went bad causing it to go rich
04-22-2016, 11:37 AM #4
I run trip motors and when 1 motor starts smoking more at idle
its usually a plug or 2 wetter than the rest,,,
change em and go,,,but mark which cyls they were
and if smokes more again shortly'
and on same cyls
then go to checking coils and injectors on them cyls
04-22-2016, 11:40 AM #5
Member
- Oct 2015
- Kennewick Wa
- 62
- 10
- 13
Slimm liked this post
04-22-2016, 11:42 AM #6
Member
- Oct 2015
- Kennewick Wa
- 62
- 10
- 13
That's kinda what I figured, thanks for the help
04-22-2016, 11:54 AM #7
well, that eliminates analog and tpi.... could be a few things but without being there i have nothin' by bein' ona computer!... don't wanna steer ya in tha wrong direction with a "very nice piece" like ya got there!... sorry. maybe these other guys can get ya goin'......
looks like that thing has never hada screw turned on it!!!Last edited by tlwjkw; 04-22-2016 at 11:56 AM.
Baja170 liked this post
04-22-2016, 12:03 PM #8
Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 492
No kidding, that is the cleanest 260 I have ever seen that has been run. WOW. Nice!!
Good luck solving the problem. I will be watching for this phenomenon and I have a spare set of plugs with my 260's. Thanks for the info!!
04-22-2016, 02:25 PM #9
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,352
- 10
- 265
- 32
- 733
Check your reeds,Chris
tux974 liked this post
04-22-2016, 04:27 PM #10
6000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Could be the reeds, air temp sensor is out of wack, injectors need to be cleaned or the very basics like spark plugs and the barb fitting that gives signal to the ecu is clogged.
04-26-2016, 07:11 AM #11
04-26-2016, 07:39 AM #12James H. W2F a V-King... Want 2 Fly a V-King
04-26-2016, 06:31 PM #13
Check the orfice that goes to the TPI. It blocks easily and often. It is easy and cheep (free) to check!!
death is certain; life is not
04-29-2016, 10:45 PM #14
Member
- Oct 2015
- Kennewick Wa
- 62
- 10
- 13
Have not had time to work on it yet but I will for sure let u guys know what vI come up with. I really appreciate the help guys
04-29-2016, 11:22 PM #15
Hole Lee sheet....that's 1 clean motor
Simple things first. .plugs...reeds...etc.etc...
Do what these guys said and report...81' HYDROSTREAM VECTOR / slightly Modified 200
2.5 Offshore mid, idle/relief exhaust ports?
By tgreen in forum Technical DiscussionReplies: 2Last Post: 06-02-2015, 08:27 AM -
Is it possible for a Looper to idle without smoking?
By imq707s in forum Technical DiscussionReplies: 21Last Post: 08-22-2014, 09:44 PM -
97 Mercury 200 EFI Offshore Miss At idle ?
By RChabit in forum Technical DiscussionReplies: 1Last Post: 07-01-2008, 11:09 AM -
260 Merc Offshore idle down problems-HELP!
By jay giroux in forum Technical DiscussionReplies: 2Last Post: 11-30-2004, 10:16 PM -
Cold idle smoking
By gtsmpuc in forum Technical DiscussionReplies: 1Last Post: 09-23-2001, 09:10 PM
