Page 9 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 121 to 135 of 198
  1. #121
    Jan 2016
    Missourj
    That's what I am thinking.....then I was told that it would be faster boat with a 250 on it lol....sounds like these 350 are way over rated
  2. #122
    May 2001
    Hickory NC
    5 Post(s)
    This maybe way off but since they told you to raise the engine before and now to install a jack plate did the dealer install the wrong length engine?
  3. #123
    Jan 2016
    Missourj
    Nope its a xl motor dor 25 inch transom....same thing j have. Always ran....unless it has the wrong lower unit on it......I guess I could measure that......my cavitation plate now is 1.5 above the bottom of boat.....they want me a minimum of 2.5. With this bravo 1 fs prop that is designed for alot of bow lift and go fast.....and I'm out of adjustment on the holes...only way to go higher is jack plate.....
  4. #124
    Dec 2006
    north end of the blue ridge, va.
    Who the hell rigged this boat? I'm thinking that person/company should be footing all this"after the fact"crap. You PAID someone to do a job CORRECTLY, they should stand behind their work, or lack thereof! This sounds like what I call "shotgun diagnostics", put enough pellets in the pattern & maybe you'll hit the problem. Typical jackleg modus operandi.
    AIRWALK
    gettin' old ain't for sissies
  5. Likes Baja170 liked this post
  6. #125
    Jan 2016
    Missourj
    Bot was rigged same way as the 2 other verados that was on it....neither here or there......it isn't going to gain 1000 rpms it is lacking and the 10 mph it is lacking from just being where the 225 was with a 300 computer
  7. #126
    Jan 2016
    Missourj
    Also brian from mercury tried to tell me today the big eco enertia wasn't a bow lifting prop at all but they advertise the prop as increased bow lift!....and one engineer told the shop to remove the pvs plugs out of but according to the other guy it needs to stay plugged off lol
  8. #127
    Mar 2006
    auckland new zealand
    Gear box will go on but the gear ratio will be different your old on 1.85 new one 1.75. but you old one may not hang together
  9. #128
    Jul 2015
    NC/TN/KY
    Get an attorney and stop messing with them. All it is doing is frustrating, costing money and stressing you out. Let your mouth piece deal with Mercury and end the BS. As long as you keep dancing, they are going to keep playing the music.
  10. Likes moparbarn liked this post
  11. #129
    Jan 2016
    Missourj
    Also I thought the shifting part of the linkage was different in my 08 225 vs this 14 350
  12. #130
    Aug 2012
    MS
    I asked before but never saw your response. Are you sure the throttle is opening all the way up on the engine?
    Put a block under the gas pedal on your truck and see if it will run wide open...
  13. #131
    Jan 2016
    Missourj
    I am assuming it is they never said anything about it
  14. #132
    Jul 2015
    NC/TN/KY
    Plus if they replace your engine and get yours back they might be able to help prevent a lot of others from having the same problem. Win-Win situation.
  15. #133
    Jan 2016
    Missourj
    They still say to much drag on gear case....well I found out my 225 gear case is interchangeable.....so I'm gonna give Tha a whirl for them
  16. #134
    Aug 2012
    MS
    Quote Originally Posted by quad143 View Post
    Optima Blue top........have actually tried 2 other batters thought maybe it would be low voltage but also no code for low voltage... here is a list that we have check
    batterys
    fuel preasure
    engine height
    exhaust restriction
    leak down test
    cylinder drop test
    cam shafts
    timing
    fuel
    fuel preasure
    All the test are passing but on the engine run file they can tell something is making a hard load on the engine....so they thought lets raise the motor.....raised it 3 holes and it stops at the same rpms...the motor just seems to go flat at those rpms.......now the tech is saying digging deep to check for a crank bearing or cam bearing that is binding in i and i dont really want a new motor with low hours on it less than 25 tore apart and re assebmled.... I have asked them to try a new computer.....These motors run on the same computer but different programming i'm really wondering if the computer has the wrong programming....like maybe a program for a 250 motor.
    This list does not say that you confirmed that you are getting full throttle. With the time and money that you are claiming to be out, I wouldn't "assume" anything. This might not be your problem, but it could definitely limit your top end RPMs, as you have described. Anything is possible, the dealer could have "assumed" that it was opening all the way, and it not be. Would be very easy to check and mark off your list. I won't mention it again
  17. #135
    Jan 2016
    Missourj
    hwo do you check on these electronic throttles if it is getting wide open throttle
  1. My new scarab w/verado , any upgrades on verado 250 ?
    By cc@100mph in forum General Boating Discussion
    Last Post: 08-03-2010, 06:28 AM
  2. Have ya'll seen this junk ?
    By RB in NM in forum The Scream And Fly Lounge
    Last Post: 09-24-2009, 11:14 AM
  3. Replies: 68
    Last Post: 02-21-2007, 07:56 AM
