Page 6 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 76 to 90 of 163
  1. #76
    My lighting at the shop is a never ending battle can't do anything without good light.
    And I have noticed gettin older hasn't helped !!! Gary
  2. #77
    Just finished R&R'ing the work bench and building a new shelf over it. Check out the light over it.The bench is bright too but phone was picking up light from the window.
    Looking good, and the light height is right. I have 4 benches with 4 foot above lights. Just right. But have 2 benches with as 3 shelf's above, the light is only 30 inches off the benches. Works fine me, but at night as eye level blinds me looking at the shelves. It all the little stuff "I shouda"? Ya got a "blank canvas...GO FOR IT!"
  3. #78
    11 Post(s)
    May add 2 more over head fluorescents when done but will wait and see. Guessing insides of the new doors will be white and once hung they'll uncover the corner walls I built for them that are also white.
    Easy to get enough light for a work bench but for glass work and painting......, there's no such thing.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. #79
    lindsay on. canada
    gary , If you make a shelf over your bench make a box with your 2x6 or 2x8 cover the top with plywood paint inside and out . Mount your lights in the box , they hide the lights , harder to break and looks good also shines more light down on the bench .Gives you a ton of shelf that takes a lot of weight .......
  5. #80
    Aint that the damn truth!
  6. #81
    Whats the workbench surface made from?
  7. #82
    I was wondering the same^^^
  8. #83
    11 Post(s)
    Thanks guys.
    Frank, love your idea. Don't really need the shelf space but would give me a "roof" to hand a curtain around to enclose the bench area and heat it.
    Bench top is sheet metal I had formed to cover my 1 1/2" thick wood surface. Always wanted one after soaking wood w/oil, snagging block studs while porting, etc, etc.
    Only regret is not spending the extra $$ and doing stainless. I have to keep coating it w/diluted 2 stroke to keep it from surface rusting in the damp air.
    Also, always wanted a bench long enough to do it all. At 16' I think I'm there
  9. #84
    11 Post(s)
    Then there's your sight...........
    I buy dollar glasses at the dollar store every time I'm there and leave them everywhere. Car, truck, shop etc, etc..........
  10. #85
    Mar 2002
    N.E. Ohio
    is that a work bench or operating table?
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  11. Likes olboatman liked this post
  12. #86
    Quote Originally Posted by MODVP22 View Post
    What's the difference!!! Gary
  13. #87
    11 Post(s)
    Headway.
    Pic 4 is rear w/last remaining sliding door open, showing hole waiting on wall to be built.
    Pic 3 is of the 2 x 6's reclaimed from dismantling first three sliding doors.
    Pic 1 is inside of opening at door 4, framed for wall using reclaimed lumber. Horizontal pc's are inside of door #4 which was closed to hold in heat (15* outside) while I built wall.
    Pic 5 is w/R-19 insulation installed.
    Pic 2 is front w/new overhead doors and stub/corner wall's installed. Stub walls are sided w/siding from dismantled doors.
    Was interesting working today that as I built and insulated that wall, my heater ran less and less.
    120K BTU heater has a thermostat on it and was set at 50* and stayed off longer and ran less. For grins I set it to 60 and the heater caught up and shut off!
    Love it.
    While still having gaps around the new doors until I install the weather stripping.
    My goal w/this project was being able to heat the shop well enough to work in it this winter. W/the project still not finished, I couldn't be happier.
    A tip to anyone considering building a barn, spend as much as you can at the start. The labor I invested to dismantle and salvage the doors, build the 4 walls, etc, etc would have cost a fortune if I had to pay someone to do it and took time I could have spent making money/doing something else.
    Plus doing it myself...., that wall is 12' tall, and the header across the top is 16' wide. Could have easily turned ugly.
  14. #88
    OK Gary...I got a problem with this. Heres a pic Nov 15th? 100 some days later now? "The hell I can't do it!..but bit at a time"! Damn "shop rat"..wish the best ya!
  15. #89
    11 Post(s)
    Quote Originally Posted by Robby321 View Post
    I thought you would appreciate the "re-purposing" of the old doors ��
  16. #90
    11 Post(s)
    I created a facebook page to show some of my past projects for those that don't know me.
    https://www.facebook.com/Two-Stroke-Only-894171173986605/?fref=ts&ref=br_tf
  17. Thanks powerabout thanked for this post
  1. Chrysler Preparing For chapter 11
    By steamengine6 in forum The Scream And Fly Lounge
    Last Post: 04-24-2009, 03:01 PM
  2. Glastron Molinari Chapter I
    By Hooty in forum Outboard and Racing History
    Last Post: 03-07-2008, 01:51 PM
  3. Ran the new boat this weekend......what a PIG, CHAPTER 3
    By Raceman in forum Technical Discussion
    Last Post: 03-10-2003, 09:07 PM
  4. Ran the new boat this weekend......what a PIG, chapter 2
    Last Post: 02-27-2003, 09:25 PM
