Results 16 to 30 of 31
Thread: Vertex or Wiseco?
11-11-2015, 09:11 PM #16
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
iv had good luck with wsm in a yamaha i built, i'v seen them last in some 2.5l a friend built, i unfortunately i didnt have the same luck in my mod vp or bridgeport,, would i have better luck with wiesco in a steel bore bridgeport motor? the other 5 stock art and 5 mahle pistons that came out lived a long time....
11-12-2015, 08:27 AM #17
Wisecos have to be good, they come in a velvet bag just like Crown Royal!
11-12-2015, 09:42 AM #18
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
11-12-2015, 04:02 PM #19
11-12-2015, 11:37 PM #20
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
ive used vertex for a long time with zero incidents thats ZERO im no seizzzzzzzzzco fan by a long shot but i dont do nuttin but merc v6 ive just recently heard about the wsm piston with the 1.5mm rings( thanks GO) with high silicone content im a fan already i will try some on the next cut all to hell block im beatin on yeah im aware of the 1.5mm ring deal on vertex depending on yer crank you may be in for some more machine work bott guide rods, pistons dont work so swell on top/g cranks small rod boss's
11-12-2015, 11:42 PM #21
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,351
- 9
- 265
- 31
- 729
11-13-2015, 12:44 AM #22
Im sure your aware but for those who are not, the Top guide rods work fine with bottom guide Vertex pistons, just have to stack or use a thicker wrist pin washer. 90% of the Prostock racers run them this way with no problems. Wsm are good but do not hold up as well for us under compression. Just my experience & some other Racers that have tried them.
11-13-2015, 03:31 PM #23
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
TC yes im also aware of the thick washers i have some around here somewhere im thinking they was on some tguide conversions on the early 260 with Mahle pistons but that was so long ago i aint tried the super wsm pistons but i do member 10 years ago or so they was ultra cheap and had no coating you could buy the whole rebuild set with bearings for under 500
11-13-2015, 05:23 PM #24
Does vertex make both top and bottom guided pistons?
Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
RIP RPM RACING
RIP GTS1
11-13-2015, 06:29 PM #25
11-13-2015, 11:40 PM #26
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
11-14-2015, 02:43 PM #27
I ran Vertex in a 260 for literally 10 years with no issues. (2004 to 2014) Could not afford the proper piston at the time.
100 MPH AND NO BRAKES!!!
2009 Full Throttle STV River Rocket
1989 STV Pro Comp Ski with a 1994 2.5 260 (Sold)
11-15-2015, 11:32 AM #28
What about Mahle?????????
Will thy hold up to 10000RPM runs from time to time................
11-15-2015, 06:58 PM #29
5000 RPM
- Mar 2009
- Seymour, Tn
- 177
I have had no problems with the Vertex but they are on back order with no ETA. I might try going with the WSM but I don't like experimenting with customer motors.
11-15-2015, 10:24 PM #30
I love the Vertex I have them in my 225 pm and in my highly modded steel sleeve and have turned them well over 9000 rpm and have held it at 8500 for a couple of miles.
1998 SS 2000 94 260ss
Speed cost how fast you want to go
Allison and Merc is there anything else?
tux974 liked this post
Vertex?
By tlwjkw in forum Technical DiscussionReplies: 2Last Post: 10-07-2009, 08:40 PM -
Vertex?
By tlwjkw in forum Technical DiscussionReplies: 2Last Post: 09-09-2009, 07:13 PM -
vertex pistons
By rick#17 in forum General Boating DiscussionReplies: 1Last Post: 08-29-2009, 03:50 PM
