Results 1 to 7 of 7
    Mar 2004
    Archer,Florida
    Drive shaft question ProMax 2.5
    I have a lower with casting # 1686-827214C. it has 44104A7 gear set which I am replacing. The drive shaft seal area is very worn and corroded and needs to be either replaced or repaired. My question is has anyone had any experience with having these seal surfaces repaired. I can have it done fairly cheaply by my friend who has been a machinist for 40+ years and is excellent at his trade. The other option is to replace the shaft, but if I'm looking at the right parts breakdown the shaft is about $1100.00 retail. Can someone tell me the difference between this shaft(848449A4)and the 897624T shaft, used on most 2.5's? Also Maybe I'm looking up the wrong lower unit, so please correct me if so.
    Jul 2002
    FT WORTH, TEXAS
    have it repaired!!! ive fixed plenty of them but with speedy sleeves , ive also added a fishing motor shaft to the torqmaster cases in lieu of the hard plated shaft they last a long long time they are stainless sorta buy a used one for a lot less just as good
  3. Likes tux974 liked this post
    Quote Originally Posted by TEXAS20225 View Post
    have it repaired plenty of them but with speedy sleeves , ive also added a fishing motor shaft to the torqmaster cases in lieu of the hard plated shaft they last a long long time they are stainless sorta buy a used one for a lot less just as good
    A stock shaft will be just fine.
    I personally do not like the speedy sleeve fix! If is not done correctly or by someone that has done them before it will not work properly, but that is just me!
    Jul 2002
    FT WORTH, TEXAS
    Tony there ya go with some of them positive statements you make you are so right on the speedy sleeve fix i screwed up my first few till i figured out it will leak under it if ya dont fix it also
    Bobby, ask me how I know and what it cost me to practice or play.........
    Mar 2004
    Archer,Florida
    Thanks for the replies. I have used speedy sleeves for other applications, but I expect difficulties with the distance from the end of the shaft to the seal area. What kind of tool did you use to get the sleeve all the way down the shaft without destroying the sleeve? This seems easier than what I had in mind which was to have it welded and turned down.
    Jul 2002
    FT WORTH, TEXAS
    speedy sleeves come with the lip on them as you know if youve done it before, i use a piece of cpvc (tan ) its just right
  9. Thanks iwannagofast thanked for this post
    Likes iwannagofast liked this post
  1. drive shaft play question
    By cterrebonne in forum Technical Discussion
    Last Post: 04-26-2008, 08:38 PM
  2. prop shaft and drive shaft question
    By eli in forum Technical Discussion
    Last Post: 03-25-2008, 01:05 PM
  3. CLE Drive Shaft Question
    By klem in forum Technical Discussion
    Last Post: 12-28-2007, 03:32 PM
  4. Drive shaft question
    By vnemous in forum Technical Discussion
    Last Post: 09-11-2007, 12:05 PM
