Results 1 to 12 of 12
    Jul 2015
    Georgia
    Forged Pistons on Mercury
    Been told not to use forged Pistons on Mercury rebuild ?
    just stock motors! Got a 2005 90 and a 2001 200efi
    opinions? Thanks
    Dec 2011
    Ludington michigan,on the shore
    Good advice,go with vertex,or the ones that CC sells,WSM?
  3. Likes CNC_Guy, merc326 liked this post
    Those days are over. Wiseco clearances the Pistons for the specific bore. I add .002 on 3.854 if it will be turned over 7000. Heat cycles are your friend.
    but why bother with forged on a stocker?
    Mar 2006
    auckland new zealand
    Why bother with forged on a stocker? well over here Kiwi land wiseco pistons are much cheaper that the merc/omc genuine units.
    Quote Originally Posted by R.grover View Post
    thats a good reason!
    Jul 2015
    Georgia
    Guess I will stay away! Thanks
  9. #8
    Ive seen the pins falling out of 200 hour factory brp Pistons numerous times. I've used some cast aftermarket that puked pins before breakin was completed these were on box stock engines.
    Wiseco pins do not come out and they are a much stronger piston. The only reason people are scared is because years ago you had to add clearance for wisecos and they would stick if you didn't. Now they add the clearance to the piston. On stock rebuilds I don't add any clearance just do a few good heat cycles.
  10. #9
    Jul 2002
    FT WORTH, TEXAS
    i guess everyone has a once upon a time story ive never lost any pin on pro or vertex pistons nearly 300 rebuilds
  11. #10
    when are we getting rings without end gaps?
  12. #11
    I live in Prineville Oregon which is in the central part of the state
    Can you explain your version of heat cycles.
    Many thanks, Carter
  13. #12
    Quote Originally Posted by TEXAS20225 View Post
    Pro supposedly had a bad run maybe only Omc Pistons were affected I lost 2 pins in one motor then 2 more in another. They knew there was an issue and sent me 4 sleeves 12 Pistons gaskets etc. No charge.
    A friend recently just lost 2 pins on a set of pro Pistons in a 3.0 Merc with break in time only never turned 6k.
    I have never had a pin move since I went to wisecos 6 yrs ago about 100 motors so far so good. The factory Etec Pistons are notorious for loose pins and cracking bowls I've never seen a wiseco do either. I guess I just sleep better knowing they have stronger more reliable Pistons . Maybe it's because some of the most powerful outboards in the world run wisecos wizards, Monty, Dave bush etc
  14. Thanks powerabout thanked for this post
