Results 1 to 5 of 5
    Mar 2010
    Brigham City, Utah
    Is it possible to Lower the Hieght of a Bimini Top?
    For the width I needed I could only find a 46 inch high top frame and I am thinking that is going to be about 10-12 inches to high and look funny. I had read somewhere about shortening the center pole and re rivet the hardware in place.
    I just think 34-36 inches tall with the center pole mounted just behind the rear windshield support frame would look better.
    Thanks for any ideas or advice.
    Karsten
    Jul 2004
    houston,tx
    most binini top frames are just allunimum tubing
    and hardware has either allen set screws or rivets'
    easy to modify to fit ur application
    go to any hardware store and get a plumbers tubing cutter
    makes cleaner,,,more even cut than a hack saw
    and no mess in boat as u do it in place to get ur fit
    Aug 2012
    Tenkiller Lake, OK
    I have done this several times. As John stated, Just measure, cut and re-rivet the hardware onto the vertical tubes, aluminum or SS. Simple.
    Quote Originally Posted by Karsten View Post
    Karsten
    Sweet Sidewinder !
    Mar 2010
    Brigham City, Utah
    Quote Originally Posted by Tom Foley View Post
    Sweet Sidewinder !
    Tom,
    Thanks, but ti is a Schuster Tahiti.....Sidewinder Splashed the hull and upper deck after Schuster Splashed the Glastron Deep Vee Hull...then to get even Schuster Splashed the Low Pro Deck...Let the law suits fly and nothing was ever settled as I understand it.
    Schuster had the barrel seats and Sidewinder had a glass V back the back seat but that is the only difference.
    Karsten
  1. engine hieght in relation to pad
    By woundedwarrior in forum Props, Setup, and Rigging
    Last Post: 10-25-2012, 10:29 AM
  2. good starting hieght for a 260 0n a T3
    By bravo 1 in forum Props, Setup, and Rigging
    Last Post: 05-30-2011, 07:52 PM
  3. Jack plate hieght
    By Jammin Joe in forum Technical Discussion
    Last Post: 05-26-2010, 03:54 PM
  4. outboard mounting hieght
    By RTD327 in forum Props, Setup, and Rigging
    Last Post: 02-11-2008, 10:57 AM
  5. Engine hieght on Mirage
    By WILDMAN in forum Technical Discussion
    Last Post: 05-18-2002, 12:43 AM
