Results 1 to 15 of 22
Thread: Yellowing gelcoat - solution?
06-08-2015, 10:32 AM #1
My Carolina Skiff has a white gelcoat, but parts of it are yellowing. Not sure why, the boat is not left outside. From what I have read, the yellowing occurs from catalyzers in the gelcoat or solvents. I've read many solutions ranging from the use of oxalic acid to wet sanding.
I was wondering if anybody here has any solutions they have tried that have worked?
Thanks!
06-08-2015, 10:35 AM #2
Screaming And Flying!
- 15,089
- 409
- 1460
- 6061
- 11728
Where is the yellow showing up at?
06-08-2015, 10:42 AM #3
06-08-2015, 10:45 AM #4
Not sure it would work in your case, but I use the Power One on mine. The yellowing on mine though is staining from being in the water over long periods of time. I like it because it works the same as pure acid products, but is not as corrosive or abrasive.
2006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
06-08-2015, 10:46 AM #5
Thanks Jeff, I'll definitely look into that! I appreciate it!
06-08-2015, 11:04 AM #6
The Historic Photo Master
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
It may or may not be a surface yellowing that comes with age as the gelcoat cures over time. This is caused by poorly catylized and or mixed gelcoat, and/or the first layer of lamination resin applied on top of the gelcoat. Fairly common in mass production boat manufacturing. Sometimes happens in smaller shops & lower production number boats as well, but not as commom. Test a small area by wet sanding with 600. High speed buff with finish compound, while noting not to heat the surface while doing so. Under-catylized gels/resins can "post-cure" if subjected to heat from a high speed polisher & will ripple or wave the surface.
06-08-2015, 11:07 AM #7
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
Then again...it could just be some poor quality wax you've applied in the past, that has finally yellowed...
CaptainCraiger liked this post
06-08-2015, 11:24 AM #8
- 15,089
- 409
- 1460
- 6061
- 11728
Try some "on and off " hull cleaner. (acid) If that won't take it off, it is in the gell. Maybe all the way thru. Goo gone makes a good acid stain remover too.
06-08-2015, 11:31 AM #9
Scream And Fly VIP
- Jan 2007
- Amityville/Lindenhurst
- 3,012
- 46
- 18
- 204
decks are rolled gelcoat over chop, maybe its areas that were gelcoated after the boat had been made. Either at the dealer or the factory before you got it
Raybo Marine http://www.raybomarine.com/
06-08-2015, 11:40 AM #10
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
06-08-2015, 11:42 AM #11
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
06-08-2015, 11:45 AM #12
Scream And Fly VIP
- Jan 2007
- 3,012
- 46
- 18
- 204
06-08-2015, 11:51 AM #13
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
Yes...This too is a possibility. You'd be surprised how many gelcoat repairs & area touch-up resprays are made "after" the boat leaves the mold at the factory. Fixes are needed due to "alligatoring", parts(boats) stuck to the mold, sharp corner chips broken due to excessive gel application in corners, laminators not using the appropriate size laminate roller(s) on the skin coat, sweat(water) dripping off the applicators forehead, causing multiple "fish-eye" contamination(s), hull slipping off the shop dollys onto the concrete floor, some dummy spraying aerosol spray silicone lubricant nearby during lamination, etc., etc., etc...lol...its endless.
Most of these quicky spray batches of gelcoat(for the repair), are a radically different recipe, and applied in an entirely different envirement, that the boats mold application was.
06-08-2015, 11:52 AM #14
It's because your hydro stream is lonely and doing bad things to your skiff while you're asleep
1990 hydrostream virage diamondpower280
06-08-2015, 12:06 PM #15
- Jan 2004
- Florida
- 38,728
- 78
- 1776
- 385
- 20492
- 4 Post(s)
