Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
    Aug 2004
    Venice, Florida
    21' Paramount
    Mercury 300 Promax
  2. #17
    12 Post(s)
    Perfect.
    When I first started putzing w/fast V bottoms I built and installed mechanical/adjustable trim tab's on most of them for when I skied w/them or knew I'd be in rough water.
    Worked great.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  3. #18
    Shreveport, La.
    Don`t forget to order the pads and screws.
  4. #19
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Da Bull View Post
    Wont need them.
    21' Paramount
    Mercury 300 Promax
  5. #20
    Apr 2007
    Quote Originally Posted by Mr. Demeanor View Post
    you can pu that together at the hardware store for a lot less money / just saying and also we use all those parts on our race cars as well still half the money from speedway motors
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
  6. #21
    Aug 2004
    Venice, Florida
    Quote Originally Posted by afr View Post
    Needs to be stainless steel and I have a dealer account with CP performance. The stuff I bought is Glenwood. Very nice material.
    I am going to wait on this until I do my 15" mid since the top of the turnbuckle will attach to the bottom of the jack plate and Ill have it all apart then anyway. Ill probably have the mid next week and then have to paint it etc.
    21' Paramount
    Mercury 300 Promax
  7. #22
    Apr 2007
    cool they got both sst and aluminum its all good just thought i would give ya a heads up
    for sale
  8. #23
    Aug 2004
    Venice, Florida
    Well that only took 4 months lol
    I added 5 degree wedges at the same time so it hard to tell how effective they are. They are set level with the bottom of the tunnel now and it seems to come off plane flatter. Holeshot has a LOT less bowrise but Im sure much if that is the wedges. ill play with the angle a bit and see how it reacts.
ID:	305781 Click image for larger version.
    21' Paramount
    Mercury 300 Promax
  9. #24
    Houston, TX
    Youre prob right about the holeshot being the wedges and the coming off plane being the tabs. Tabs will do that...help support the boat on top of the water longer before the water just finally collapses and the boat drops. Its all about psi...and you just added more "i" to carry the boat. Nice work!
  10. #25
    Feb 2005
    seattle
    find a sail boat vender. they have lot of turn-buckels in stainless.
  11. #26
    East Wallyworld Vt
    I bet if you lower the trailing edge ¼" you will know what they provide. That would be adding a fair bit of hook to the tunnel to level the hull at low speed. I expect this hook would have minimal effect once you are up and running.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  12. #27
    N/A
    Quote Originally Posted by MCRacing View Post
    You have no idea of the forces on a tunnel tab even when its up, on my 21 Skater the Merc K tab has broken multiple times from not being stout enough. I have had the ram push rod break and go completely through the plane, the forces back there are incredible. My point don't use cheep crap, TT are very dangerous. Good luck see you in Key Largo
    Very old thread; S&F still comes back as top search's for me, so I figured I would update and pay forward. Couldn't agree more with all the points above. We did a custom tab on my 25' cat and worked fantastic; I just scored the attached, Xmas came early this year.
  13. #28
    Feb 2011
    HUDSON, FLORIDA
    I bought some 6x9 ss bennit tabs, trashed the actuators, 4 ss encapsulated 10'' turnbuckles, 8 ss u brackets, commercial school lavatory supply house bathroom brackets, turnbuckels have jaw ends. worked beautiful, skater18, 1 on each sponson end. above 35, there above the water,just helps me plane quicker + they look awesome. built a tunnel tab, did not work at all.
