Results 16 to 28 of 28
Thread: Building a tunnel tab
05-07-2014, 11:42 PM #1613' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
05-09-2014, 05:46 AM #17
Perfect.
When I first started putzing w/fast V bottoms I built and installed mechanical/adjustable trim tab's on most of them for when I skied w/them or knew I'd be in rough water.
Worked great.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
05-09-2014, 07:13 AM #18
Don`t forget to order the pads and screws.
05-09-2014, 08:04 AM #19
05-09-2014, 08:09 AM #20
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
05-09-2014, 08:30 AM #21
Needs to be stainless steel and I have a dealer account with CP performance. The stuff I bought is Glenwood. Very nice material.
I am going to wait on this until I do my 15" mid since the top of the turnbuckle will attach to the bottom of the jack plate and Ill have it all apart then anyway. Ill probably have the mid next week and then have to paint it etc.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
05-09-2014, 08:40 AM #22
cool they got both sst and aluminum its all good just thought i would give ya a heads up
for sale
09-10-2014, 09:20 PM #23
Well that only took 4 months lol
I added 5 degree wedges at the same time so it hard to tell how effective they are. They are set level with the bottom of the tunnel now and it seems to come off plane flatter. Holeshot has a LOT less bowrise but Im sure much if that is the wedges. ill play with the angle a bit and see how it reacts.
21' Paramount
Mercury 300 Promax
09-13-2014, 07:58 AM #24
Youre prob right about the holeshot being the wedges and the coming off plane being the tabs. Tabs will do that...help support the boat on top of the water longer before the water just finally collapses and the boat drops. Its all about psi...and you just added more "i" to carry the boat. Nice work!
09-13-2014, 07:10 PM #25
7000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
find a sail boat vender. they have lot of turn-buckels in stainless.
09-15-2014, 04:10 AM #26I bet if you lower the trailing edge ¼" you will know what they provide. That would be adding a fair bit of hook to the tunnel to level the hull at low speed. I expect this hook would have minimal effect once you are up and running.ill play with the angle a bit and see how it reacts.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
Yesterday, 02:42 PM #27
Supporting Member
- Jan 2013
- N/A
- 194
- 18
- 70
Yesterday, 04:56 PM #28
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,938
- 590
- 100
- 514
- 624
I bought some 6x9 ss bennit tabs, trashed the actuators, 4 ss encapsulated 10'' turnbuckles, 8 ss u brackets, commercial school lavatory supply house bathroom brackets, turnbuckels have jaw ends. worked beautiful, skater18, 1 on each sponson end. above 35, there above the water,just helps me plane quicker + they look awesome. built a tunnel tab, did not work at all.
