Results 166 to 180 of 265
Thread: FrankenRude Three Dot Oh
09-18-2013, 06:08 AM #166
09-18-2013, 07:21 AM #167
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,321
- 1056
- 411
- 4710
- 2169
- 9 Post(s)
I always wondered how a Taylor front half would go on anything from a 2.7 block and up with just carbs even the original carbs?
it that an easy path for more power at higher revs?
09-18-2013, 08:31 AM #168
09-18-2013, 10:12 AM #169
- Jun 2007
- 9,321
- 1056
- 411
- 4710
- 2169
- 9 Post(s)
09-18-2013, 06:03 PM #170
Making headway.
My pistons spent 2 wks waiting on my machinist before going some place else. They had them back to me the next day but I did pay the going rate to have them done there..
$168. but that ain't bad.
I left an additional .010" on these to tighten up my squish band a bit.
Kevin, yes. Been working on the new place every day, all day for the last month. Trying to get the motor together before losing my compressor w/the move until I build my garage and then pole barn.
*EDIT*
Forgot, here's a couple pix's. Cut pistons and the cut stocker I drilled through to check dome thickness.
And powerabout, if you mean the X front 1/2 they do make more power but are a bitch to get the linkage set up correctly and near impossible to get them to open in sync.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
09-18-2013, 10:21 PM #171
09-19-2013, 05:52 AM #172
Very cool Beef. Good luck.
09-19-2013, 07:13 AM #173
Pistons look great but I like short skirts
Beefs lit off hope to get the gordon/timing advance/yamaha choke solenoid done today. That should help us find the thin spot in these domes
Squish ended up slightly tighter then I thought (rookie mistake) but only .003 should be fine, there is no part numbers to transfer on these pistons
09-19-2013, 12:08 PM #174
How much port work did you guys do in that thing kevin? Just some routine cleanup or?
. Mid bore carbs?
09-19-2013, 12:44 PM #175
09-19-2013, 07:25 PM #176
09-19-2013, 08:19 PM #177
09-19-2013, 08:20 PM #178
Maxwell said they scream a lot!!!
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
09-19-2013, 08:30 PM #179
Kinda like a merc!!!!!!
09-20-2013, 04:06 AM #180
Resume on im done picking!!! I think i really maybe a omc man at heart just cant afford what i want yet!!! Cant wait to see how this build goes
