Page 12 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 166 to 180 of 265
  1. #166
    Jul 2009
    Crawfordville fl
    Quote Originally Posted by wanagofass View Post
    This thread's got me motivated to sell off my 3.0L parts and find a 3.3L.
    Got u mtivated to go black!!!!! Lol.
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
  2. #167
    I always wondered how a Taylor front half would go on anything from a 2.7 block and up with just carbs even the original carbs?
    it that an easy path for more power at higher revs?
  3. #168
    Bush says the front half is a small piece of the puzzle. They will help but there is no miracle setup, its about 1000 little things that make power and take eons to do correctly.
    Gary- Any updates or are you still in moving mode?
  4. #169
    Yep always the story
    whoever tests most, wins
  5. #170
    Making headway.
    My pistons spent 2 wks waiting on my machinist before going some place else. They had them back to me the next day but I did pay the going rate to have them done there..
    $168. but that ain't bad.
    I left an additional .010" on these to tighten up my squish band a bit.
    Kevin, yes. Been working on the new place every day, all day for the last month. Trying to get the motor together before losing my compressor w/the move until I build my garage and then pole barn.
    *EDIT*
    Forgot, here's a couple pix's. Cut pistons and the cut stocker I drilled through to check dome thickness.
    And powerabout, if you mean the X front 1/2 they do make more power but are a bitch to get the linkage set up correctly and near impossible to get them to open in sync.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. #171
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    fired mine up today hope to do some fine tuning tomorrow and hope to get it in the water tomorrow afternoon(i hope)
    sounds good tho started real quick and sounded pretty stout
    Mirage RR
    Lake Tarpon Boyz!!!
  7. #172
    Very cool Beef. Good luck.
  8. #173
    Pistons look great but I like short skirts
    Beefs lit off hope to get the gordon/timing advance/yamaha choke solenoid done today. That should help us find the thin spot in these domes
    Squish ended up slightly tighter then I thought (rookie mistake) but only .003 should be fine, there is no part numbers to transfer on these pistons
  9. #174
    Aug 2010
    N.Florida
    How much port work did you guys do in that thing kevin? Just some routine cleanup or?. Mid bore carbs?
  10. #175
    Jul 2009
    Crawfordville fl
    I told u get off the omc threads!!!! Once u go black u never go back!!!!!!
  11. #176
    Aug 2010
    N.Florida
    Quote Originally Posted by bigbluechevy454 View Post
    Well you know what they say.... "If you can't beat em', join em'". But then again, they also say.... "You'll never know unless you try" Sooo....
  12. #177
    Jul 2009
    Crawfordville fl
    You right ive always wanted to try a black girl!!!!! So does that mean u do to!!! Lol
  13. #178
    Jul 2009
    Crawfordville fl
    Maxwell said they scream a lot!!!
  14. #179
    Jul 2009
    Crawfordville fl
    Kinda like a merc!!!!!!
  15. #180
    Jul 2009
    Crawfordville fl
    Resume on im done picking!!! I think i really maybe a omc man at heart just cant afford what i want yet!!! Cant wait to see how this build goes
