Page 62 of 88 FirstFirst ... 12 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 ... LastLast
Results 916 to 930 of 1315
  1. #916
    Lannon WI
    Quote Originally Posted by HAZMATT View Post
    maybe from space
    Snotty! !! Lunar orbit snotty
    2006 Action Marine Comp
    1980 Ventrua 2
  2. #917
    Appleton,Wi.
    After talking to Mercury for 3 days I finally found out what it is.Any guess's.Who's up on their 80'3 outboards.
    Matt
    '89 Hydrostream Valero bowrider yt
    '83 Mariner Formula 200 prototype Experimental aircraft association fuel injectiion
    Hydrostream Owners Group
    North American On Plane Towing Association
  3. #918
    v-200
    And its black wishing to be white..
  4. #919
    May 2006
    Edgerton, WI
    Oval port 200 with a Formula EFI rated at about 230 crank HP. Blocks were originally unpainted with a light-weight flywheel and 2-piece heads. Haven't personally run one, but I hear they are a pretty decent motor when up and running.
  5. #920
    Lannon WI
    Quote Originally Posted by josh7_78 View Post
    Nicely done Josh
    1980 Ventrua 2
  6. #921
    May 2006
    Edgerton, WI
    Quote Originally Posted by Laker View Post
    Nicely done Josh
    There have been a couple threads on this particular motor as people tend to think they are a bridge port. Being an unpainted block, having EFI, and the flywheel, I can see that. However, they are an oval port. It should be a pretty strong runner on that boat; will we see it on the water soon?
  7. #922
    Appleton,Wi.
    Winner winner chicken dinner according to mercury this a 1983 mariner formula efi prototype.According to the serial number.Bad news no parts ,service manual nothing,It has a experimental aircraft efi now not the original.It runs and sounds awesome.Snotty YES!!!!It is on the water and will continue to be.
    Matt
  8. #923
    Canada, East!
    Quote Originally Posted by FlowMaxx View Post
    Thanks bud, you have been a big part of it too And Pointer, let me know when you can make the trip and we will plan a power tour
    That would be awesome! Thanks for the offer! Won't be this year, but I know how to reach out to you!
    pointer
  9. #924
    Jan 2005
    Shawano Lake
    Quote Originally Posted by hydrostreamvking4m View Post
    Wide open for HydroStreams.
    Excellent job, Looking Good
    1987 V-King YT 200 Evinrude Vindicator
    1998 16' Weers HPT Pontoon 60 Evinrude 36 MPH
  10. #925
    Thanks Bob,
    Its been a fun build but is still in the works for a pad job and bottom freshin up..As long as are winter was this year spring came in 2 fast for me to get all done as i was in hopes of doing..
  11. #926
    Jan 2005
    Shawano Lake
    Brian,
    Did you remove all the foam from the sponsons? It appeared from the pictures that it was removed. It must have been a lot of weight savings. I am thing that mine might be partly water soaked on the one side?? I used to run the speedo pick up there and tore it off a couple of times.
    Bob
  12. #927
    I did..And call me crazy but i put it right back in..My hull at one time in its life went over and was upside down for some time and yes put water into the pass side sponson..However just like you ive had the water pick up pulled (ripped) off the drive side sponson more times then i can count..And would you know that wing showed no water in it at all...But the pass side wing had alot...Its no walk in the park to remove that junk....But to replace the core in the bottom of the sponsons you realy need to.(and my core was rotted).I added drain tubes that runs from the rear of the sponson to the front of the hull.. I glassed it down and went to pouring in the new foam..I also added drain plugs in the rear of the wings..Along with adding the one brace on the tail end of each.....
    I drilled 100s of tiny holes on the bottom side of the tubs so the new foam could not enter into it..And it all worked out as planned..
  13. #928
    Jan 2005
    Shawano Lake
    Brain
    Looks like you did an excellent job, sure is a lot of work but you did it the right way. By putting the foam back in at least you know it as strong as it was when it new and the drain tube are great to drain and possible water that could get in there. Do you have any idea the difference in weight from before and after?
    Bob
  14. #929
    Lannon WI
    Quote Originally Posted by daytrader View Post
    Sunday I saw a crazy lookin dude in a silver stream with tattoos from azzhole to elbow on the wolf. Wonder who that was?
    Bomb BOMB
    1980 Ventrua 2
  15. #930
    Nov 2005
    MAINE
    heyyyyyyyyyyyy Josh.........................Click image for larger version.
