Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 51
    Nov 2009
    hardyville va
    My Outrageous STV Project
    Just finishing my 3 litre STV project. I was not sure if the boat could handle the big motor, but so far so good. I've only got 3 hours on the motor so i'm keeping it under 5500rpm. She runs from 80 past 100 pretty quick. Got a couple pics to share if anyone is interested.
    Attached Thumbnails Attached Thumbnails DSCN4110.jpg   DSCN4112.jpg   DSCN4113.jpg   DSCN4114.jpg   DSCN4120.jpg
  2. Likes panther150 liked this post
    Nov 2009
    hardyville va
    Should be. Will dyno it after I get a little more time on it .
    Feb 2005
    Muskoka Canada
    3.4?
    What did you do?
    2023 TUFF 25
    Nov 2009
    hardyville va
    Quote Originally Posted by RBT View Post
    3.4?
    What did you do?
    Stroker crank,.40 overbore,porting,carbon reeds,high compression,light flyweel,bigbore intake,special reedplate,56psi. fuel,special injectors,drystack,exhaust tuner,balanced,1.62 sporty,34" lighting et.and more.
    Apr 2007
    subscribed
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
    12 Post(s)
    Quote Originally Posted by afr View Post
    subscribed
    ditto
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Maurepas, Louisiana
    Who did your motor work and what about fuel management? Interesting...........
    Russ Benton
    Allison XB-2003 w/JSRE Pro Max
    Allison XR-2001 w/260 +
  9. #8
    Jun 2008
    kingman az
    cool project...cant wait to hear the dyno numbers
  10. #9
    Nov 2009
    hardyville va
    Quote Originally Posted by RB in NM View Post
    The ECU is motorola 555 from a 496 ho v8.Basiclly a core.Eric Simon did the program.The VST is from an early Opi as well as the hi pressure pump.I modified the vst to flow fuel from the float tank directly to the pump chamber.Lo pressure is holley red in the boat.The fuel rail is modified stock efi merc.The pressure reg and injectors are from Marren in Conn.All the fittings and hose are Areoquip socketless 6 AN.I did all the motor work myself.
  11. #10
    Jun 2008
    on the river north of Blarney
    looks this should be insane
    im watchin
  12. #11
    Apr 2007
    lets see its stance sitting in the water got any pics of it wet
    for sale
  13. #12
    Nov 2005
    MAINE
    Quote Originally Posted by dnr78 View Post
    im watchin
  14. #13
    Nov 2009
    hardyville va
    It doesn't set much lower than it did with the BP on it.We took a Flip camera with us over the week end.I'll try to put some of it on here.
  15. #14
    Nov 2009
    hardyville va
    I ran the boat over the weekend.Got a Livorsi 120 GPS tattle tale speedo. Very close to pegging it with a 200 pound passenger. Ran around 115 solo and got a scary speed wobble. It's stable with 2 people. Still have the rubber mounts in it.Got solids coming this week. Using sea star pro steering,feels pretty tight. Any thoughts or suggestions? Thanks
  16. #15
    St Cloud,Fl
    Yes be very careful and wear a good jacket
    "Conklin Racing" M/E 0494
    Sponsers,Conklin Racing, Speed-N-Sport Marine
