Results 1 to 15 of 33
Thread: Transom/hull step for speed????
08-15-2011, 04:08 AM #1
Can you guys please explain to me why some of the more modern hulls have a step at the rear of the planing surface and the transom?
At what sort of speed would this type of modification start to have an effect?
Does this mod on the Liberator effectively reduce the need for setback?
I have also seen this mod on V hulls.
I hope Randy doesn't mind me using a couple of photo's of his boat.
Attachment 240552Last edited by Smoking Joe; 08-15-2011 at 04:28 AM. Reason: trying to sort photo's
VinTin thanked for this post
08-15-2011, 07:32 AM #2
Supporting Member
- Jul 2004
- Connecticut
- 6,253
- 520
- 210
- 1078
- 1133
Guys have done it and there are a variety of opinions. What hull are you thinking of doing this to?
08-15-2011, 03:14 PM #3
Hey Greg, thanks for the photo. I am about to remove the sterndrive from a Wellcraft Nova 230 XL, reconfigure the transom and bracket a Johnson 300hp V8 on it. Since I will be doing plenty of transom work any mods that can be done at the same time to add speed will be worth doing.
I have a hydraulic Jack Plate for the engine. Would really like to see late 60'smph but I appreciate that this may be unrealistic with 300hp.
I may also look to go with a Monty's power head which would give me another 70hp or so.
08-15-2011, 03:41 PM #4
5000 RPM
- Aug 2002
- New England/MA & NH mostly
- 668
..What a great question..!..Would like to know the story on the step.!.Some discussion of pads would be tolerated too.. My thoughts on SJ's (Hi
Wellcraft and what you're doing with the bracket & V8 makes the step a moot point. A pad would be a "maybe", ONLY if you want to change what is a great design to begin with..discuss away...
PS..been watch your journey..you da man.. SJ.. your mate from the granite state..Vtoy..>> IF YOU'RE GONNA RUN WITH THE PACK...YOU CAN'T PISS LIKE A PUPPY !!!<<
08-15-2011, 10:43 PM #5
This is interesting. I think it applies more to high mph racing but good info nonetheless.
http://www.velocityboats.com/Safety.htmlThe Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
08-16-2011, 04:35 AM #6
Hey Vtoy hows it going dude. I sure appreciate the pedigree of the Wellcraft hull, I had thought of putting a pad on it too. Now I am thinking that I will flag that idea. If the 300hp V8 is not fast enough and I like the V8 then I will buy another and get it to NZ via Monty. Another alternative is to put two 225hp's or go to Merc 300XS or maybe even 350 Verado.
When I rebuild the transom I will make it strong enough to handle twins.
"you da man..." With the difficulties I have faced with this "journey" you should have heard what my wife had to say about this "trip". Something along the lines of "you da stupid man, what is wrong with the thousands of boats for sale in New Zealand". These women just don't understand us mere males.
Take care mate.
Nev.
08-16-2011, 04:38 AM #7
08-16-2011, 05:12 AM #8
From what I understand, a stepped transom gives the prop cleaner, more undisturbed water to run in, making it more efficient. Hydrostream did it very early on and till the end.
1977 Viper
08-16-2011, 05:40 AM #9
I think it acts like setback. I believe they call this built-in setback.
That way you already have more setback without running a jackplate or setback plate.
So the benefit is the same as the setback => increase bowlift....
Correct me if I'm wrong.
08-16-2011, 06:14 AM #10
So does it only work with a V hull sporting a pad or does the same principles apply to a V hull without a pad???
08-16-2011, 06:59 AM #11
Supporting Member
- Jul 2004
- Connecticut
- 6,253
- 520
- 210
- 1078
- 1133
Here is an added pad that is going on one of my boats. Give me details on the 230XL, beam, deadrise, weight, do the strakes run right to the transom?
08-16-2011, 04:48 PM #12
Thanks Greg. I would like to see some clearer photo's, looks like an interesting exercise. Unfortunately my container has been held up by some inclement weather (my boat is still on the ship and is yet to arrive) so I am unable to supply measurements. I am probably getting a bit ahead of myself but seeing the photo's of Randy's tunnel motivated me to ask the question.
Thanks for your input.
Nev.
08-16-2011, 06:52 PM #13
08-16-2011, 06:56 PM #14
08-16-2011, 07:55 PM #15
Hmmm, do I take it you are not a fan of the Wellcraft Nova then.........Mine is a 1985 Wellcraft Nova 230 XL.
Joe , more lift......which means less wetted surface , which means more speed .................
Yup that broad principle I understand. But specifically how does the transom step help with lift and speed????
