Results 1 to 15 of 18
    Dec 2010
    steer me right! 20' allie
    hey guys, just paid for a 1976 allison 20'. $500! Ive got myself an 88 200 blackmax, bobs cone lower, and a jackplate waiting to go on it when i pick it up, i was looking for a good starting point for a prop for speed, i will definatly be doing absolutly NO skiing with this rig! Any help would be appreciated
    1989 hydrostream vegas xt. 200gt johnnyrude...
    1989 Grady white Tournament 19 w/ 1998 Evinrude 175
    1990 grady white marlin 30 w/ T 250 hpdi yammies
    Yamaha 5 star certified Tech
    Mercury Certified Tech
    Certified Bastard
    Apr 2006
    Great East Lake, Acton, Maine
    Unless there's someone on s&f that has a similar boat, you're going to have to get it wet and try it out. then post peak rpm, top speed, holeshot ,engine height, prop pitch/style, and setback. With that info we can tell you how to tune in you setup.
    1984 Nordic pickel fork. 2.5L 245 carb, CLE. top speed: 95mph with more to go
    Sep 2009
    Lake One
    Contact Todd at Hydromotive, KNOWS props and Ally's...http://www.hydromotive.com/news.html
    "have you met my little fly named scream?"
    GSE #1 2004 GSE, 2004 225X Promax... RIP
    GSE #2 2013, Gen2 200XS ROS
    Dec 2010
    Juggernaut, that is a very valid point! i have a couple props laying around for my buddies viper, he said i can try some of those out, a mix of choppers and cleavers. Thanks for the contact h20, i will definatly give him a shout
    Certified Bastard
    Sep 2009
    Lake One
    Allison Forum
    Quote Originally Posted by Taver View Post
    Taver, Have you been to the Allison Forum yet? If not, stop over lot of good people and info.
    Pic's of our GSE, at Hydromotive, setting up prop height and getting a general check-up on our way from picking up in ARK.
    Last Season on the "Big Water"
    Attached Thumbnails Attached Thumbnails Allison Trip 063.jpg   user2207_pic316_1305837377.jpg
    Prince George B.C. Canada
    Like Robert said above. Join the Allison Owners Site. Its a forum like this one and very active so youll get answers right away. Oh and a big welcome to the Allison Family! There will be lots of guys that can steer you right in setup with the Black Max in regards to setback, motor hight,props etc.. Hears a link. Just register then you can see the whole site. Between this site and Allison owners your need are covered. There are many other sites also but these two for you will work best for now. http://forum.allisonowners.com/index.php
    Regards
    James Watson
    May 2002
    S.E.Ct.
    What model is your Allison?
    Mar 2004
    Lexington SC
    I ran a 30 Hoss on mine it was a 20' 78 or 79 model ran very good
    Dec 2010
    its a 1978 gt20, the jackplate i have for it has a 7" setback
    Certified Bastard
    Oct 2010
    Harrisburg,Pa
    Stock 200 14 1/2or1/4X 26 Hoss or 14'X 28 Hoss maybe Triton 1. Start 1" below
    May 2002
    S.E.Ct.
    GT-20’s like round ear props and they like the prop down in the water. As stated start at an inch or inch and a quarter with 26p prop. Depending on the condition of the hull bottom GT-20’s run with their nose in the air. Be careful letting off the throttle quickly at speed they can get squirrelly. 7in. set back should be fine, mine is 8in. You will need to keep weight on the port side when running solo with side steer. With this setup you should run in the low to mid 80’s. Once you’re comfortable with the setup play with raising the prop and try all the props you can find. Good luck.
  12. #12
    Dec 2010
    the engine is a little better than stock, not much work done, just reeds, and big bore carbs. I plan on mounting the battery on the port side to help with weight distibution a little. i have a 26 chopper that was modified to a 28, i might try that first, but i do have a stock 26 chopper i could borrow from a buddy. thank you for all your input guys
    Certified Bastard
  13. #13
    May 2002
    S.E.Ct.
    Keep us up on your progress. Pictures if you can.
  14. #14
    Dec 2010
    will do, i start the remaining glass work tomorrow, need to buy a new camera, mine took a swim!
    Certified Bastard
  15. #15
    Nov 2010
    united states
    Hammer down trim up!!!Simple as that.
