Page 58 of 102 FirstFirst ... 8 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 ... LastLast
Results 856 to 870 of 1526
  1. #856
    May 2008
    Glen Spey, NY
    Quote Originally Posted by mikeylarge View Post
    Keep that same tank of gas for the romp, and I'm doomed!!!!!!!!!!
    It's all in the prop...
  2. #857
    Jan 2007
    lindenhurst
    Quote Originally Posted by VELOCITY 3.6GT View Post
    Can I ask what pitch? and what rpm you saw 81??? You can keep the prop itself a secret if you want, just curious on pitch and rpm
  3. #858
    May 2008
    Glen Spey, NY
    I am running a 26 trophy plus right before the rev limiter turns the motor to an idle. 6125 rpm. I put a spacer inbetween the prop and the lower unit. The spacer directs the gasses all through the hub and does not allow any to go over the hub. It seems to help with the speed but I am not sure why. The big difference is the choppy water. I need to get my hands on a 27 trophy to try. I have not used the 26 raker since the last romp... only could spin at 5500rpm's top speed 74.
  4. #859
    Suffern, NY
    Is that a blow out ring your talking about.
  5. #860
    May 2008
    Glen Spey, NY
    I believe so. It snaps onto the lower unit.
  6. #861
    Suffern, NY
    One of these, goes on with 4 set screws?
    Defuser Ring. What it's designed to do is use the elevated lip to create a vortex bringing water closer to hub for a better bite, and less chance of blowout. Some of the old Merc cases had a small rib around the back of the case that did the same thing. Don't see it anymore cause the Merc cases are so hydrodynamic and the OMC cases are still lacking in this dept, hence the need for the blowout ring.
    See ya at the Romp. 81 is an awesome speed with a 250 and a cabin hull. Sounds like that E Tech is pumpin pretty good.
  7. #862
    Suffern, NY
    Hey
    A special shout out to Cutwater.
    I think I'm bringing 2 boats this time and I'll show ya how I cloned myself to drive 2 at a time.
  8. #863
    Jan 2007
    lindenhurst
    81 is is even a better speed considering its a 225! I guess i have to step up my game for next year
  9. #864
    May 2008
    Glen Spey, NY
    They all cheat with the numbers 225ho =248 . James gang it is just like that just no screws, it clips on. Thanks for explaining it. Mikey I am sure you'll be up to the game... something tells me you don't like to loose especially to a blue motor. Those pictures you posted were bad ass.. Just curious is your hull kevlar it seems to carry very well.
  10. #865
    Suffern, NY
    Went out boating yesterday and noticed my Sportys have the lip I was talking about. I guess there not as hydrodynamic as the CLEs were. Anyway I guess your engines are pretty dependable when you forget what they look like.
  11. #866
    Jan 2007
    lindenhurst
    My hull is defiantely not kevlar, but the way the boat carries itself is just prop and motor height/setback. Less boat in the water= faster. =D
  12. #867
    Jun 2005
    near Lake George, NY
    Mikey, Rick,
    you guys coming to Romp II?
    1983 Shadow 21, Yamaha 250 HPDI
    1961 Grumman 13, Johnson 15, "Gunkhole"
    1931 Hacker Hydro, Phantom 75
    1930 Sea Lyon 28, Scripps 208, "Tomahawk"
    1929 Chris Craft 24, Chrysler 115, "Reflection"
    _________________________
    Photography:
    KAOS Imagery
    Flickr
    Facebook
  13. #868
    May 2008
    Glen Spey, NY
    I'll be there with the wife and kids. I should get there Friday evening. Its a 4 hour drive to get the boat in Ti then a two hour ride there.
  14. #869
    Jun 2005
    Cool!
    I'm in Ti until Thursday eve, too bad I couldn't snag the boat and get it down closer for you...
    Photography:
    KAOS Imagery
    Flickr
    Facebook
  15. #870
    Jan 2007
    lindenhurst
    Won't be back up there until the spring time. Hopefully The romp isnt the first weekend in june because I have a wedding that weekend. I would be coming up this weekend but the boat is currently under the knife
