Page 57 of 102 FirstFirst ... 7 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 ... LastLast
Results 841 to 855 of 1526
  1. #841
    Aug 2005
    port orchard , wa
    Looking at Navispeeds 01 I found some a difference on the hulls.Some time after 98 they added a small lip on the further most strake when looking at the side.From what I can tell that helped eliminate the porpoise the the 94-98 at least hulls had.I believe thats why the newer hulls can get away with vastly smaller or no trim tabs at all.On 94 to 98 at least hulls they seem to need much larger trim tabs.I have 12X9 and there not nearly enuff,the boat porpoises from 35-50 unless its trimed down or completely trimed out and wide open.What size trim tabs and on the 94 and up STEPP hulls are you running.The earlier boats are alot lighter and probably not effected as much.
  2. #842
    Jul 2005
    MD
    HighVelocity, did you mean to say a 1986 velocity hull?
    Quote Originally Posted by HighVelocity View Post
    Like Mikey Large,,, I am running a 2003 225EFI 3.0L fishing motor...haha I have a 12inch Bobs hydraulic plate.
    Prop is a 26P 4 blade by Percision Propeller. It's lighter than a Bravo and weighs about the same as a Trophy,,,but because of the diameter, it works great on my set-up. It really digs and pulls the bow up with the set back. I am very happy with it...
    Also, my hull, like Mike's has the very thin top deck...1996 hull, bullet is about 2 1/2 below the pad. 1:75 ratio.
  3. #843
    Nov 2005
    Egg Harbor Twp. NJ
    Quote Originally Posted by modvp View Post
    It is a 1986. Ed was drinking too much the day he posted this.
    David
    ______________________
    2000 Powerplay Sportdeck
  4. #844
    May 2008
    Glen Spey, NY
    Try a 26 trophy... About 3mph faster than a 26 raker.... And alot more bow lift. Guys just remember a boat in fresh water is usually around 2-3 mph slower than a boat in salt water... Something on how the boat carries. Mikey nice shots!!!
  5. #845
    Jan 2007
    lindenhurst
    Quote Originally Posted by VELOCITY 3.6GT View Post
    Fresh water is less dense then saltwater. The water density helps support the weight of the boat better when floating, and also allows the prop to bight harder, which is why slatwater runs faster. Also alot of lakes have higher elevation then sea level which creates a slight power loss issue as well!
  6. #846
    Aug 2005
    port orchard , wa
    Quote Originally Posted by mikeylarge View Post
    We boat at sea level,both salt and fresh water.On a small padded bottom boat you wont see a 3mph difference.Youd have a better chance see a difference with the current.The cruiseing speeds may be a bit faster in salt,simply becouse more of the boats in the water.The difference is very small when only the pad and prop are in the water.
  7. #847
    May 2008
    Glen Spey, NY
    Mikey large when you were at Sacandaga you lost quite a few mph's right as compared to runnin on Long Island? Thanks for explaining the water differences. The last Romp the air quality was horrible for makin power.
  8. #848
    Aug 2005
    port orchard , wa
    I agree air makes a huge difference.I usualy try to test first thing in the morning at a lake neer us.Its at 150ft so altitude isnt a problem,and I seem to get the best numbers there.
  9. #849
    Jan 2007
    lindenhurst
    With my dad and fuel in the boat, she ran like a pig. I was getting 73-74 and the boat just felt stuck to the water. Back home with my dad in teh boat i can run 77-78 any day. Towards the end of teh day we were messing around and I was almost out of gas. With about 10 gallons in teh tank, and without my dad i put a 78 mph pass down at the lake. The altitude combined with the freshwater definately makes a huge speed and acceleration difference.
  10. #850
    Anyone remember an all blue gelcoat 22 O/B race boat from the mid-80's, called Captain Maintained? Bill Kaye raced it out of Chicago and was national champion for three years in a row in the class. Wonder if anyone has video of this boat racing, on YouTube?
  11. #851
    Suffern, NY
    I remember seeing pictures of it. A friend of mine had it in a calender of offshore race boats years ago. Would love to see video of it running.
  12. #852
    Quote Originally Posted by JamesGang View Post
    I would too. There is some incredible original tape out there, of the boat going...where no man has gone before...lol
  13. #853
    May 2008
    Glen Spey, NY
    Mikey I saw 81 the other day with a nice chop and 80 degrees fresh water and a 1/2 tank of gas. I must agree that last romp was not a good day for power.
  14. #854
    Jun 2005
    near Lake George, NY
    Me and Rick on comin' to LI sometime and with the salt water advantage, we'll probably hit 100
    Seriously, the bouyancy difference is measurable...
    1983 Shadow 21, Yamaha 250 HPDI
    1961 Grumman 13, Johnson 15, "Gunkhole"
    1931 Hacker Hydro, Phantom 75
    1930 Sea Lyon 28, Scripps 208, "Tomahawk"
    1929 Chris Craft 24, Chrysler 115, "Reflection"
    _________________________
    Photography:
    KAOS Imagery
    Flickr
    Facebook
  15. #855
    Jan 2007
    lindenhurst
    Keep that same tank of gas for the romp, and I'm doomed!!!!!!!!!!
