Results 1 to 8 of 8
07-25-2010, 09:09 AM #1
HST transom installation: how did they do this at the factory?
Hi,
I wonder how they laminated the transom of the HST back in the day. I think there are 3 options. Anyone know how they did it?
1/ Laminate transom in the deck before putting two halves together
2/ Laminate transom in the hull before putting two halves together
3/ Put two halves (deck and hull) together and laminate the transom from the inside
Thx
07-26-2010, 11:31 AM #2
3/4" ply in the deck, 3/4" ply in the hull. Top deck and Hull joined together and then a full sheet of 3/4" ply running across both the topdeck/hull seam for a total of 1.5" thick ply plus the glasswork.
Paramount 21/Merc 225 EFI
Cobalt 263/VP 8.1L
Nova Spyder 230/454 Mag
Barracuda 188CCR/Suzuki 140
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT/Merc 175
Talon T-21/Mercury 245hp carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/454 Mag
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat
SeaRay 17' Seville
07-26-2010, 03:34 PM #3
07-27-2010, 12:25 PM #4
I know the AE-21 was built that way. I spoke to John Spaeth up in Canada regarding the build and strength of the transom on the AE-21..I could only assume that the HST would be similar. It's much easier to laminate a sheet of 3/4 ply to the top deck and another sheet of 3/4 ply to the hull while they are apart versus crawling under the rear deck and attempting to do the same...but you will have to crawl under there anyway to laminate the second "solid" sheet of 3/4" ply that would cover the seam between the top deck and hull....
Cobalt 263/VP 8.1L
SeaRay F16 Jet boat
SeaRay 17' Seville
07-27-2010, 03:36 PM #5
Big boy does this mean you are putting your together soon??
91 Voyager XT 92 Yamaha 225 2.6l heads jets reeds mounts tuner bob's cone.
1990 HST. S3000 15"os mid,sporty.
07-28-2010, 03:37 PM #6
Well I hope so. It doenst hurt to ask some info at front.
I just digged all the foam out. Prob going to take the floor out this weekend.
07-30-2010, 04:50 PM #7
If I remember correctly, The transom wood was laminated into the hull first then the deck was put on and the rest was glassed in.
[/SIGPIC]
07-30-2010, 05:28 PM #8
Thats possible. Although I think it would be better the other way round (first laminate the wood in the deck because this is a larger area)
Thx for your input.
