Results 1 to 8 of 8
    Jun 2004
    port st. lucie, fl
    gearcase parts interchange discussion
    ok, lets talk gearcases and what you found will interchange and won't, so far i've found that the torquemaster and sporty/200/cle cases have different length carriers, i've also found that the propshaft od on the bearing surface is a different size(200 propshaft is smaller in this area), but i haven't measured the id of the bore in the sporty carrier to see if a 200 or cle pshaft bearing would fit, so lets get a discussion going as far as interchangeability
    Sep 2002
    Dunlap,TN.
    The early CLE carrier will work with the 200 prop shaft. I have a fleet case with that HD carrier out of a 2 hole CLE and had to make a thick shim to get to tighten up. Working great so far. Hope this helps.
    James Perry
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by wrechin2 View Post
    thats what i found, seems the torkmaster and certain cle carriers are shorter then a 200/sporty carrier. i would like to use a torkmaster carrier in a 200 case w/ a cle shaft, but i think that the propshaft bearing size is going to be an issue
    Sep 2002
    Dunlap,TN.
    I may be mistaken, I think the later CLE's have the "FAT" shaft and would work with the HD carrier out of a TM. I have one out of torque master that I am going to make a sleeve to adapt the standard bearing down. It would just need to be steel or aluminium and have the correct tolerances just like installing a sleeve in a engine. I will make it where it still uses the snap ring and will be bored just deep enough for 1 bearing. I may even cut a groove in it for a snap ring. A little Loc-tite bearing retainer. Should be good. Just my thought.
    James Perry
    Jun 2004
    port st. lucie, fl
    excellent idea
    Sep 2002
    Dunlap,TN.
    Maybe I will do it sometime this winter. If I get caught up. But not in need of it right now is also a factor. LOL!!
    James Perry
    Jul 2002
    FT WORTH, TEXAS
    gearcase stuff
    man this is a lot of variable info to try and put in print just about all 2 hole cle had the 1.81 dia. prop shaft but not all!!! same as fishin mota some of the early a torqmaster did have a shorter carrier up OG6 number motas then they went to same as Sportmaster and latest models 4 hole CLE's had all same gears and propshaft different carriers on some ! some with rear drains some with out!! some early CLES 2 hole had a dual beaing carrier inline with a special long bearing race on the shaft. looking at MY Midas electronics parts catalog really is not the whole story because when Mercury superceeds a part number the old one goes away it still exists in the real world but not available to us info wise 135,150,200 are all the same case 1647-9147 then numbers progress as case design changes a little over a few years but not much there were actually about 4 or 5 different designs from Mercury on the CLE options over the years im not really sure i have had a lot of gearcase parts to mess with 3.0 liter cases are a horse of another color very simalar to 2.5 case's in a lot of ways drive shaft bottom end is exact to each other on the late models spline is different and so on i can identify just aout any part by its stamping if that will help you. and if you need a little heavier carrier in your 200 case just use a starndard 3.0 carrier same shaft size but twice as heavy looks like a cle carrier
    Jun 2004
    port st. lucie, fl
    thanks, that's what i was tring to figure out, what will interchange
