    Mar 2007
    Ontario, New York
    Quote Originally Posted by Schramer View Post
    Just picked up the motor I will be building for it ten minutes ago
    V8 Rude?
    Dan Cario
    1994 STV Mod-VP w/225HO Ficht Evinrude
    1987 22' Velocity w/225HO Evinrude E-Tec
  2. #2627
    WI
    I don't think it would float!
    I have a boat or two.... that I never get to drive
  3. #2628
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    lol do it!!
    Mirage RR
    Lake Tarpon Boyz!!!
  4. #2629
    Mar 2007
    Ontario, New York
    listen to beefkid hes knows what hes talkin about
    Dan Cario
  5. #2630
    Nov 2007
    Quote Originally Posted by Baja16 View Post
    lol im wantin to lighting my action up and V8 the biotch!! but the weight to hp ratio aint worth it... put my mota on that biotch and get it spinnin 9400 with a 24 like it does!! you will SHIOT!!!
    Mirage RR
    Lake Tarpon Boyz!!!
  6. #2631
    I don't think you guys have any clue how light this boat is. The deck is as thin as a plastic water bottle. It would sink with a V8 and a Looper V6 weighs more than the boat does....
  7. #2632
    Jun 2001
    Waupaca, Wisconsin
    OK just so my foggy brain is up to speed, was this Dukes Vector?
    16' Inland TigerShark Flatbottom/
    1978 Merc1400withXS Mid
    coming soon: 2.4 220 Lazer EFI/Marty Powell 15"mid
    1988 Weeres 24ft pontoon/30hp Evinrude party barge
    1991 STV Pro Comp/Mercury 1996 2.5 260
  8. #2633
    Sure was.!
  9. #2634
    a v6 looper would be fine on that comp, it doesnt weigh any more then that pos hyd plate and the 20in crossflow
    it might whoop some ass if its not a weight game, if it had to make weight it would be a different story
  10. #2635
    Aug 2004
    Lake Wissota, Wi.
    Thumbs up Xflow
    At least the Crossflow can still turn 7200R's after 32 years, better than any merc could do after 2 yrs. without a rebuild.
    335lb. Vector, 750lb. Ventura II
    Hydrostream Addict Hot Evinrude 200 crossflow
  11. #2636
    Lannon WI
    Uhh no... My LooperV4 weighs what a Flow6 weighs..
    2006 Action Marine Comp
    1980 Ventrua 2
  12. #2637
    everyone that says they are too heavy have never done it
    loopers 450 a flow is 400 with that plate/pump its close. If you put a looper on a diet you can shed 30-40lbs fairly easily. A barsh cowling and non fast track will get it down more
    the way things are looking theres gonna be one with a looper on it next to my house
  13. #2638
    Nov 2007
    and its gonna have a nice motor that kinda looks like this on
    Mirage RR
    Lake Tarpon Boyz!!!
  14. #2639
    Lannon WI
    I know OMC said 450 but they were heaver than that when actually weighted with a scale... Some where there is a B&WB magazine at my house where JTjr did actual weights of motors with calibrated equipment and found what the manufactures were a little optimistic on the weights they published.
    I weighed my Looper 4 at Bakers in 2003 with the same scale they weighed the boats with and it was 417lbs...
    1980 Ventrua 2
  15. #2640
    Quote Originally Posted by Laker View Post
    they were only optimistic on looper weight? barsh scale says 400 lbs as well (16in)
Page 176 of 187 FirstFirst ... 76 126 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 LastLast
